Need some help with confirming my error
  • Pandabird
    • Apr 2020
    Hey everyone, I have recently been getting multiple bsod, on the daily. I ran the test and it failed. Specifically on test 4, with an insane amount of errors, I dont know what to make of it, so I tried to follow the troubleshooting page for memtest, hence I updated my Bios for now, I just really want to know if its a RAM problem, or if it could be something else. Im getting many crashes in rendering 3D visuals, as well as plenty of crashes in games, and most of my bsod mention kernel, irql not equal or less, and other similar. These are my results: Summary
    Report Date 2020-04-16 02:01:53
    Generated by MemTest86 V8.4 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer Micro-Star International Co., Ltd
    Product Name MS-7A34
    Version 2.0
    Serial Number To be filled by O.E.M.
    BIOS
    Version A.70
    Release Date 09/20/2017
    Baseboard
    Product Name B350 PC MATE (MS-7A34)
    Version 2.0
    Serial Number H816378930
    CPU Type AMD Ryzen 7 1700 Eight-Core
    CPU Clock 2560 MHz [Turbo: 3200.3 MHz]
    # Logical Processors 16
    L1 Cache 16 x 96K (49804 MB/s)
    L2 Cache 16 x 512K (45795 MB/s)
    L3 Cache 1 x 16384K (21703 MB/s)
    Memory 32731M (14235 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-19200
    G Skill Intl / F4-2400C15-8GVR
    15-15-15-35 / 2400 MHz / 1.200V
    DIMM Slot #1 8GB DDR4 XMP PC4-19200
    DIMM Slot #2 8GB DDR4 XMP PC4-21300
    G Skill Intl / F4-2666C15-8GVR
    15-15-15-35 / 2666 MHz / 1.200V
    DIMM Slot #3 8GB DDR4 XMP PC4-21300
    Result summary
    Test Start Time 2020-04-15 20:01:14
    Elapsed Time 4:24:18
    Memory Range Tested 0x0 - 81F380000 (33267MB)
    ECC Polling Enabled
    # Tests Passed 28/28 (100%)
    Lowest Error Address 0x3D0000 (3MB)
    Highest Error Address 0x4BFFFC (4MB)
    Bits in Error Mask 00000000FFFFFFFF
    Bits in Error 32
    Max Contiguous Errors 2
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 3/3 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 3/3 (100%) 0
    Test 2 [Address test, own address] 3/3 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 3/3 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 2/2 (100%) 712232
    Test 5 [Moving inversions, random pattern] 2/2 (100%) 0
    Test 6 [Block move, 64-byte blocks] 2/2 (100%) 0
    Test 7 [Moving inversions, 32-bit pattern] 2/2 (100%) 0
    Test 8 [Random number sequence] 2/2 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 2/2 (100%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 2/2 (100%) 0
    Test 13 [Hammer test] 2/2 (100%) 0
    Last 10 Errors
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 4, Address: 4BFF98, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 3, Address: 3D0048, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 4, Address: 4BFF9C, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 2, Address: 3D0064, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 3, Address: 3D0044, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 4, Address: 4BFFA0, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 2, Address: 3D0060, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 3, Address: 3D0040, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 4, Address: 4BFFA4, Expected: 80808080, Actual: 7F7F7F7F
    2020-04-16 00:25:31 - [Data Error] Test: 4, CPU: 3, Address: 3D003C, Expected: 80808080, Actual: 7F7F7F7F
    This is more indicative of a firmware bug.
    The addresses at fault are very low in memory and and very precise range. Plus all 32bit are in error.
    Not at all random, like a typical RAM fault would be.
    Might be that some hardware device is using the 3MB to 4MB memory range, but the BIOS didn't notice and flagged the addresses as free RAM. Resulting in memory corruption.
    • Pandabird
      • Apr 2020
      What would you suggest as a solution? The bios update did not work, if anything it put me on a bluescreen loop where I could not even get to my desktop without a blue screen. I took out two of the rams I had bought as an upgrade two months ago, and the problem is solved for now, for the first time I was able to play 2-3hours without a single crash. Does that mean that one or both of the ones I took out are faulty in some way? Sorry but as a real begginer in pc tech knowledge I did not fully understand your reply as to what exactly is the problem!
        If there is no problem with 16GB of RAM, try swapping the pairs around, just to prove all the RAM is good.
        It might be a firmware bug that only occurs with 32GB.
        • Pandabird
          • Apr 2020
          I think one of them is faulty, since I took my second pair of 16gb out, I put one of them in, which had 24gb total, and caused a bsod loop again, turned pc off took it out, put the other one of the new pair in and everything works. So this ends up happening only with one out of the two new sticks! Im guessing that just means that one of them is faulty right?
            The would be logical. The initial error really didn't look like a RAM failure, but it can't be ruled out either.
            With 3 sticks the memory access pattern will change as you will no longer in dual channel mode.
            But there is a strong principle in diagnostics. If it works don't fix it.
