Memtest86 errors, Test 10 and Test 13 Help Diagnose
  • wb123
    • Apr 2020
    Looking for some feedback regarding a most recent memtest86 run i did. I occasionally get a blue screen of death web browsing and playing pc games.
    Is it possible to identify the exact memory stick that is causing my system to crash?
    Summary
    Report Date 2020-04-27 17:57:13
    Generated by MemTest86 V8.3 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.10
    System
    Manufacturer To be filled by O.E.M.
    Product Name To be filled by O.E.M.
    Version To be filled by O.E.M.
    Serial Number To be filled by O.E.M.
    BIOS
    Version 2501
    Release Date 04/03/2014
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name M5A99X EVO R2.0
    Version Rev 1.xx
    Serial Number 120801522200601
    CPU Type AMD FX-8350 Eight-Core
    CPU Clock 4014 MHz [Turbo: 4013.9 MHz]
    # Logical Processors 8
    L1 Cache 8 x 80K (35348 MB/s)
    L2 Cache 8 x 2048K (27466 MB/s)
    L3 Cache 1 x 8192K (10134 MB/s)
    Memory 16308M (7244 MB/s)
    DIMM Slot #0 4GB DDR3 XMP PC3-12800
    Corsair / CMZ16GX3M4A1600C9
    9-9-9-24 / 1600 MHz / 1.500V
    DIMM Slot #1 4GB DDR3 XMP PC3-12800
    DIMM Slot #2 4GB DDR3 XMP PC3-12800
    DIMM Slot #3 4GB DDR3 XMP PC3-12800
    Result summary
    Test Start Time 2020-04-27 16:53:20
    Elapsed Time 1:03:23
    Memory Range Tested 0x0 - 43F000000 (17392MB)
    CPU Selection Mode Single: CPU # 0
    ECC Polling Enabled
    # Tests Passed 10/11 (90%)
    Lowest Error Address 0x42D771314 (17111MB)
    Highest Error Address 0x42D771314 (17111MB)
    Bits in Error Mask 0000000002000000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 1/1 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 1/1 (100%) 0
    Test 2 [Address test, own address] 1/1 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 1/1 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 1/1 (100%) 0
    Test 5 [Moving inversions, random pattern] 1/1 (100%) 0
    Test 6 [Block move, 64-byte blocks] 1/1 (100%) 0
    Test 7 [Moving inversions, 32-bit pattern] 1/1 (100%) 0
    Test 8 [Random number sequence] 1/1 (100%) 0
    Test 9 [Modulo 20, ones & zeros] 1/1 (100%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/1 (0%) 1
    Test 13 [Hammer test] 0/0 (0%) 5
    Last 10 Errors
    2020-04-27 17:51:58 - [Data Error] Test: 13, CPU: 0, Address: 42D771314, Expected: 4C2E2C7A, Actual: 4E2E2C7A
    2020-04-27 17:45:10 - [Data Error] Test: 10, CPU: 0, Address: 42D771314, Expected: 00000000, Actual: 02000000
    Looks like RAM is bad. See this page to start with
