Errors on nearly every test
  • FullOfNaCl
    • May 2020
    I decided to look up why I was getting BSODs that had an error code of "memory_management" and saw that I should run MemTest86 to see what's wrong. I ran it and had over 8000 errors, but I don't know how to decipher the results and logs to see what caused all of this. If anyone could help me with this, it would be appreciated.
    Here is what I got: Summary
    Report Date 2020-05-07 15:31:52
    Generated by MemTest86 V8.3 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.60
    System
    Manufacturer System manufacturer
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 0215
    Release Date 09/05/2017
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name TUF Z370-PRO GAMING
    Version Rev 1.xx
    Serial Number 170910419504524
    CPU Type Intel Core i7-8700K @ 3.70GHz
    CPU Clock 3737 MHz [Turbo: 4847.9 MHz]
    # Logical Processors 12 (6 enabled for testing)
    L1 Cache 4 x 64K (217076 MB/s)
    L2 Cache 4 x 256K (94223 MB/s)
    L3 Cache 12288K (42171 MB/s)
    Memory 16330M (23490 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-25600
    G Skill Intl / F4-3200C16-8GTZR
    16-18-18-38 / 3200 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-25600
    Result summary
    Test Start Time 2020-05-07 12:39:44
    Elapsed Time 2:51:17
    Memory Range Tested 0x0 - 46F000000 (18160MB)
    ECC Polling Enabled
    # Tests Passed 31/48 (64%)
    Lowest Error Address 0x1F8028510 (8064MB)
    Highest Error Address 0x1FA030698 (8096MB)
    Bits in Error Mask 0000000020000000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 3 [Moving inversions, ones & zeroes] 2/4 (50%) 6
    Test 4 [Moving inversions, 8-bit pattern] 3/4 (75%) 1021
    Test 5 [Moving inversions, random pattern] 2/4 (50%) 2708
    Test 6 [Block move, 64-byte blocks] 2/4 (50%) 904
    Test 7 [Moving inversions, 32-bit pattern] 2/4 (50%) 2649
    Test 8 [Random number sequence] 3/4 (75%) 56
    Test 9 [Modulo 20, ones & zeros] 2/4 (50%) 102
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 1/4 (25%) 379
    Test 13 [Hammer test] 2/4 (50%) 187
    Last 10 Errors
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA02A3F0, Expected: 00800000, Actual: 20800000
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA02A2F0, Expected: 00080000, Actual: 20080000
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA02A038, Expected: FFFFFEFF, Actual: DFFFFEFF
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029FF8, Expected: FFFFFF7F, Actual: DFFFFF7F
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029F30, Expected: 00000010, Actual: 20000010
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029C30, Expected: 02000000, Actual: 22000000
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029C20, Expected: 02000000, Actual: 22000000
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029B28, Expected: FFDFFFFF, Actual: DFDFFFFF
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA029AF8, Expected: FFEFFFFF, Actual: DFEFFFFF
    2020-05-07 14:52:09 - [Data Error] Test: 6, CPU: 6, Address: 1FA0297F0, Expected: 00000100, Actual: 20000100
    Looks like the RAM is bad. See this page to start with
