Test Failure, just need some general advice
  • creyldor
    • May 2020
    Hi There,
    I've been using memtest86 a long time and it has helped me to identify bad ram out the box and other hardware issues. However, after 7 years I got a couple of lockups then a blue screen in windows with the stop code MEMORY_ERROR or similar.
    I fired up the latest memtest86 and low and behold I have errors reported.
    I am 99.9 per cent sure this is a ram issue, although after 7 years of operation I am surprised the ram suddenly went bad. My PSU and CPU all seem to be operating in normal parameters so at this point, I am hoping its the memory at fault and not the motherboard.
    I have already pulled the trigger on new ram anyway but I'm really just looking to see what others thought of the results, the html results state the following:
    Lowest Error Address 0x120110754 (4609MB)
    Highest Error Address 0x122111070 (4641MB)
    Bits in Error Mask 0000000000000200
    Bits in Error 1
    Max Contiguous Errors 1
    Test 3 [Moving inversions, ones & zeroes] 0/4 (0%) 19
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 79
    Test 5 [Moving inversions, random pattern] 0/4 (0%) 117
    Test 6 [Block move, 64-byte blocks] 3/4 (75%) 4
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 374
    Test 8 [Random number sequence] 0/4 (0%) 79
    Test 9 [Modulo 20, ones & zeros] 1/4 (25%) 8
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/4 (0%) 4
    Test 13 [Hammer test] 0/4 (0%) 66
    Last 10 Errors
    2020-05-31 10:33:17 - [Data Error] Test: 13, CPU: 0, Address: 120110754, Expected: C354E2D4, Actual: C354E0D4
    2020-05-31 10:32:08 - [Data Error] Test: 10, CPU: 0, Address: 120110754, Expected: FFFFFFFF, Actual: FFFFFDFF
    2020-05-31 10:13:58 - [Data Error] Test: 9, CPU: 2, Address: 120110754, Expected: 916C7B97, Actual: 916C7997
    2020-05-31 10:08:53 - [Data Error] Test: 8, CPU: 2, Address: 120110754, Expected: 2FA1768E, Actual: 2FA1748E
    2020-05-31 09:59:21 - [Data Error] Test: 7, CPU: 2, Address: 120110754, Expected: FFDFFFFF, Actual: FFDFFDFF
    2020-05-31 09:50:58 - [Data Error] Test: 5, CPU: 2, Address: 120110754, Expected: 010D8679, Actual: 010D8479
    2020-05-31 09:47:55 - [Data Error] Test: 4, CPU: 2, Address: 120110754, Expected: 7F7F7F7F, Actual: 7F7F7D7F
    2020-05-31 09:46:45 - [Data Error] Test: 3, CPU: 2, Address: 120110754, Expected: FFFFFFFF, Actual: FFFFFDFF
    2020-05-31 09:34:00 - [Data Error] Test: 13, CPU: 0, Address: 120110754, Expected: 3258EB00, Actual: 3258E900
    2020-05-31 09:31:07 - [Data Error] Test: 10, CPU: 0, Address: 120110754, Expected: FFFFFFFF, Actual: FFFFFDFF
    A total number of errors about 524 over 4 passes pretty sure its memory, the computer seems alright in operation but it's just a matter of time I reckon.
    Thoughts?
    Looks like bad RAM.
    • creyldor
      • May 2020
      Yup thought so,
      Got the replacement through from the manufacturer today and ran a test with no issues, old ram has a lifetime guarantee lets see if they honour it.
      Not sure why it went bad, after all has no moving parts and my case sits at about 47 degrees (celcius) so its not heat
      Ahh well will have to chalk that up to experience.
