Result: FAIL - Wow, I think I have an issue here...
  • jasonn
    • May 2014
    Can you help me understand what is wrong with my laptop?
    It's random crashing and rebooting even when nothing is going on.
    I've took out the 8GB that came with it when I bought it 6 months ago, and installed a different set of 8GBx2.
    From reading this forum, it seems like my next testing steps would be to test 1 RAM at a time in each slot.
    Any help would be great.
    I've pasted the MemTest86-Report below. (Is sending pics I took of the screen during the test of any use?)
    Thank you,
    jasonn
    [IMG]file:///C:/Users/Developer2/Desktop/mt86.png[/IMG]
    Summary
    Report Date 2014-05-03 22:36:02
    Generated by MemTest86 V5.0 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.31
    CPU type Intel Core i7-4700MQ @ 2.40GHz
    Measured CPU Speed 2394 MHz [Turbo: 2394.5 MHz]
    # Logical Processors 8
    L1 Cache 64K (190666 MB/s)
    L2 Cache 256K (49723 MB/s)
    L3 Cache 6144K (37074 MB/s)
    RAM 16399M (17786 MB/s)
    DIMM #0 8GB DDR3 PC3-12800
    Kingston / KHX1600C9S3/8G
    9-9-9-27 / 800 MHz / 1.5V
    DIMM #1 8GB DDR3 PC3-12800
    Result summary
    Test Start time 2014-05-03 15:28:15
    Elapsed Time 6:54:03
    Memory Range Tested 0x0 - 44FE00000 (17662MB)
    CPU Selection Mode Single (CPU #0)
    # Tests Passed 13/44 (29%)
    Lowest Error Address 0x2000451E0 (8192MB)
    Highest Error Address 0x3FFFF7AA0 (16383MB)
    Bits in Error Mask 0000000052000000
    Bits in Error 3
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 1 [Address test, own address, 1 CPU] 3/4 (75%) 3
    Test 2 [Address test, own address] 1/4 (25%) 5
    Test 3 [Moving inversions, ones & zeroes] 0/4 (0%) 151
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 5275
    Test 5 [Moving inversions, random pattern] 0/4 (0%) 14384
    Test 6 [Block move, 64-byte blocks] 0/4 (0%) 184941
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 2836
    Test 8 [Random number sequence] 1/4 (25%) 8
    Test 9 [Modulo 20, ones & zeros] 0/4 (0%) 42095
    Last 10 Errors
    [Data Error] Test: 9, CPU: 0, Address: 3FDA22E00, Expected: 0CE216C2, Actual: 4CE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FC84C8C0, Expected: 0CE216C2, Actual: 4CE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FC84C500, Expected: 0CE216C2, Actual: 4CE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FD1DC1A0, Expected: 0CE216C2, Actual: 4CE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FE118000, Expected: 0CE216C2, Actual: 4CE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FD1139C0, Expected: 0CE216C2, Actual: 0EE216C2
    [Data Error] Test: 9, CPU: 0, Address: 3FD154E40, Expected: F31DE93D, Actual: F11DE93D
    [Data Error] Test: 9, CPU: 0, Address: 3FCEED260, Expected: F31DE93D, Actual: B31DE93D
    [Data Error] Test: 9, CPU: 0, Address: 3FD8CFB00, Expected: F31DE93D, Actual: B31DE93D
    [Data Error] Test: 9, CPU: 0, Address: 3FD802240, Expected: F31DE93D, Actual: B31DE93D
    • 11127
    Yes, there is something wrong with the machine.
    Yes, try 1 stick at a time. Sometimes just re-seating the RAM in the slot can fix it. You might want to try the original stick as well, if you still have it.
    • jasonn
      • May 2014
      Great advice. I tried every combo with my 2 sticks and 2 slots. Plus used the OG chip in each slot too. I'm super happy to report it's not a defective slot on my laptop. One of my 2 sticks is defective. So my defective kit is now packed up and ready to send back for an RMA. Thank you, David! Your software is making lives better!
      • jasonn
        • May 2014
        Just to report, I got my RMA back (took a week), re-installed the memory, ran MemTest86, and instead of a quarter of a million errors, I now have zero errors! It's good to be back. Thanks again Passmark!
          • 11127
          It is always nice to hear the end of the stories. Especially the happy endings.
