took too long to finish testing
  • frozen_sun
    • May 2019
    Yesterday I ended up the tetsting at test #8 because memtest took around 1.5 h and still didn't finish.
    So I ask you does the usb flash memory type matter because I made bootable memtest86 on some old pen drive which is USB 2.0?
    Would it make it faster to end up testing if I make it on usb 3.0 pen drive.
    My memory is Corsair Vengeance RGB 4x8GB DDR4 3200MHz.
    There is some logging to the USB drive. So there might be a slight different in speed.
    But the main factors determining the test duration are,
    - How much RAM you have
    - If you are running single threaded or multi-threaded testing
    - The RAM and CPU speeds
    - The MemTest86 config settings (which tests are being run & number of test passes).
