MemTest86 v5.1.0 problems
  • mixb
    • Jun 2014
    mobo ASUS Z97-A BIOS 1008
    intel i7-4770
    4x4Gb Kingston HyperX KHX1600C9D3P1K2/8G (2x4Gb KIT)
    video GV-N770OC-2GD
    SSD INTEL SSDSC2CW060A3
    HD Hitachi HDE721010SLA330
    PIONEER DVD-RW DVR-220
    I using USB Drive MemTest86 V5.1.0 Free Edition from Image for creating bootable USB Drive.
    When I try to run an older version, I get a black screen with a string:
    NTLDR is missing
    Press CTRL+ALT+DEL to restart.
    How to boot the old version MemTest86?
    When I try to run UEFI version, all ok, but:
    1. SPD information not available - does not show a list of memory stick
    2. run the test - the screen of the program shifted to the right and down, some elements are not drawn
    NTLDR is missing
    Were you able to boot the old, non dual-boot v4.3.7 image?
    Please send or upload the MemTest86.log file under EFI\BOOT\ of your USB drive.
    • mixb
      • Jun 2014
      MemTest86.log https://www.dropbox.com/s/xaysijj6pgkqfwd/MemTest86.log
ID:	34891Click image for larger version
      real snapshot - page overlay and offset images, no elements
      I updated BIOS - nothing has changed
        I note that the screen shot you posted shows you are using a beta release of V5.0, and not V5.1.
        The log seems to show V5.1 however. Also the CPU you claimed to be running, i7-4770, doesn't match your initial screen shot, i7-2600.
        If you have multiple machines and multiple versions of MemTest86 it would help if you stated what versions had what problems on what hardware.
        • mixb
          • Jun 2014
          Initial screen shot from your site (http://www.memtest86.com/images/memtest_test.png).
          For example, to show what elements are not drawn.
          I use:
          mobo ASUS Z97-A BIOS 1204
          intel i7-4770
          video GV-N770OC-2GD
            We believe we may have a fix for the issues you are experiencing. We'll have a build up for you to test early next week.
              Please give this build a try and let us know if you are still experiencing the issues:
              http:/www.passmark.com/ftp/memtest86-usb-5.1.1b.1003.zip
              • mixb
                • Jun 2014
                Thanks, I will test today
                • mixb
                  • Jun 2014
                  1. SPD information is now available.
                  2. screen elements that were missing are now available.
                  3. the screen of the program still shifted to the right and down.
                    Thanks. The console display is controlled by the firmware, and not by MemTest86. So the shifted console is either due to a BIOS setting or a bug in the firmware. I would check the BIOS setup for any related settings, and also see if there are any firmware updates available.
