Memory errors after hardware changes
  • SGLATT
    • Oct 2020
    After installing a new mobo, PSU, SSD, and adding 2 more sticks of the exact same memory, I am getting occasional blue screens (especially when attempting to play WoW). I ran the test with the following results. What should I be seeing here?
    Summary
    Report Date 2020-10-02 17:45:28
    Generated by MemTest86 V8.4 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer Micro-Star International Co., Ltd.
    Product Name MS-7B18
    Version 1.0
    Serial Number Default string
    BIOS
    Version 1.A0
    Release Date 08/11/2020
    Baseboard
    Product Name MAG Z390 TOMAHAWK (MS-7B1
    Version 1.0
    Serial Number K316679642
    CPU Type Intel Core i7-9700K @ 3.60GHz
    CPU Clock 3646 MHz [Turbo: 4820.7 MHz]
    # Logical Processors 8
    L1 Cache 4 x 64K (254808 MB/s)
    L2 Cache 4 x 256K (122794 MB/s)
    L3 Cache 12288K (62474 MB/s)
    Memory 32716M (24692 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-23900
    Team Group Inc. / TEAMGROUP-UD4-3000 / 010415C7
    16-18-18-38 / 2998 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-23900
    Team Group Inc. / TEAMGROUP-UD4-3000 / 0104FA25
    DIMM Slot #2 8GB DDR4 XMP PC4-23900
    Team Group Inc. / TEAMGROUP-UD4-3000 / 010415CB
    DIMM Slot #3 8GB DDR4 XMP PC4-23900
    Team Group Inc. / TEAMGROUP-UD4-3000 / 0104FA28
    Result summary
    Test Start Time 2020-10-02 12:10:36
    Elapsed Time 5:34:18
    Memory Range Tested 0x0 - 86E000000 (34528MB)
    ECC Polling Enabled
    # Tests Passed 41/48 (85%)
    Lowest Error Address 0x4A8A0B44 (1192MB)
    Highest Error Address 0x8685263A0 (34437MB)
    Bits in Error Mask 000000000010008C
    Bits in Error 4
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 6 [Block move, 64-byte blocks] 1/4 (25%) 11
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 0/4 (0%) 20
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2020-10-02 16:44:14 - [Data Error] Test: 8, CPU: 1, Address: 8022803C4, Expected: 1DED61BF, Actual: 1DED61BB
    2020-10-02 16:42:55 - [Data Error] Test: 8, CPU: 5, Address: 410D8C8C0, Expected: E21DB70D, Actual: E20DB70D
    2020-10-02 16:42:41 - [Data Error] Test: 8, CPU: 1, Address: 3425956E0, Expected: 9D6EB6B4, Actual: 9D7EB6B4
    2020-10-02 16:42:04 - [Data Error] Test: 8, CPU: 4, Address: 16C158F38, Expected: C6911BB6, Actual: C6811BB6
    2020-10-02 16:41:50 - [Data Error] Test: 8, CPU: 4, Address: 4FDDA344, Expected: B0B7A29F, Actual: B0B7A29B
    2020-10-02 16:26:28 - [Data Error] Test: 6, CPU: 5, Address: 8685263A0, Expected: 00000400, Actual: 00100400
    2020-10-02 16:26:28 - [Data Error] Test: 6, CPU: 5, Address: 8677263C0, Expected: 00000400, Actual: 00100400
    2020-10-02 15:13:01 - [Data Error] Test: 8, CPU: 0, Address: 5FD3D0D00, Expected: BC454D6C, Actual: BC554D6C
    2020-10-02 15:11:38 - [Data Error] Test: 8, CPU: 6, Address: 1B77EF984, Expected: AFC1A29F, Actual: AFC1A29B
    2020-10-02 14:55:42 - [Data Error] Test: 6, CPU: 7, Address: 7BAEB5920, Expected: 00800000, Actual: 00900000
    Test 13 [Hammer test] Warning
    Note: Your RAM may be vulnerable to high frequency row hammer bit flips. However the conditions needed to induce these errors occur only very rarely in normal PC usage, and so this should not be of concern to most users.
    There is a fair chance the RAM is bad. See this page to start with
