Need a little help with test results
  • Gnatty
    • Oct 2020
    I'm not sure if this means something is wrong with my ram or my cpu, I'm pretty dumb when it comes to trying to read these types of things.
    eport Date 2020-10-21 20:38:09
    Generated by MemTest86 V8.4 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer To Be Filled By O.E.M.
    Product Name To Be Filled By O.E.M.
    Version To Be Filled By O.E.M.
    Serial Number To Be Filled By O.E.M.
    BIOS
    Version P1.30
    Release Date 07/12/2019
    Baseboard
    Manufacturer ASRock
    Product Name X570 Phantom Gaming 4-CB
    Version
    Serial Number
    CPU Type AMD Ryzen 7 3700X 8-Core
    CPU Clock 3600 MHz [Turbo: 4350.5 MHz]
    # Logical Processors 16
    L1 Cache 16 x 64K (243946 MB/s)
    L2 Cache 16 x 512K (89313 MB/s)
    L3 Cache 1 x 32768K (25297 MB/s)
    Memory 16325M (16684 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-23900
    A-DATA Technology / DDR4 3000 2OZ / 096C0000
    16-20-20-38 / 2998 MHz / 1.350V
    DIMM Slot #1 8GB DDR4 XMP PC4-23900
    A-DATA Technology / DDR4 3000 2OZ / 1F6C0000
    Result summary
    Test Start Time 2020-10-21 20:31:17
    Elapsed Time 0:00:33
    Memory Range Tested 0x0 - 41F380000 (16883MB)
    ECC Polling Enabled
    # Tests Passed 1/4 (25%)
    Lowest Error Address 0x13710144 (311MB)
    Highest Error Address 0x13717EBC (311MB)
    Bits in Error Mask 0010000000100000
    Bits in Error 2
    Max Contiguous Errors 2
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 1/1 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 0/1 (0%) 501
    Test 2 [Address test, own address] 0/1 (0%) 485
    Test 3 [Moving inversions, ones & zeroes] 0/1 (0%) 4099
    Test 4 [Moving inversions, 8-bit pattern] 0/0 (0%) 5098
    Test 5 [Moving inversions, random pattern] 0/0 (0%) 0
    Test 6 [Block move, 64-byte blocks] 0/0 (0%) 0
    Test 7 [Moving inversions, 32-bit pattern] 0/0 (0%) 0
    Test 8 [Random number sequence] 0/0 (0%) 0
    Test 9 [Modulo 20, ones & zeros] 0/0 (0%) 0
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/0 (0%) 0
    Test 13 [Hammer test] 0/0 (0%) 0
    Last 10 Errors
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710FD4, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710FCC, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710F2C, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710F24, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710F14, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710F0C, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710DB4, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710DAC, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710DA4, Expected: 80808080, Actual: 80908080
    2020-10-21 20:31:49 - [Data Error] Test: 4, CPU: 3, Address: 13710D9C, Expected: 80808080, Actual: 80908080
    Probably bad RAM.
    See this page to start with
