Memtest86 fail help
  • MisoPiso
    • Nov 2020
    Memtest86 fail help
    i have ran memtest86 3 times 4 passes. On the first run i had two fails as the one bellow. On the second none, on the third run again. Does it mean that RAM is failing or should i check some other stuff beforehand?
    Summary
    Report Date 2020-11-02 17:16:46
    Generated by MemTest86 V8.4 Free (64-bit)
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer Gigabyte Technology Co., Ltd.
    Product Name B450 AORUS ELITE
    Version Default string
    Serial Number Default string
    BIOS
    Version F52
    Release Date 07/29/2020
    Baseboard
    Version x.x
    CPU Type AMD Ryzen 5 2600 Six-Core
    CPU Clock 3428 MHz [Turbo: 3428.3 MHz]
    # Logical Processors 12
    L1 Cache 12 x 96K (76724 MB/s)
    L2 Cache 12 x 512K (58925 MB/s)
    L3 Cache 1 x 16384K (26703 MB/s)
    Memory 16350M (14476 MB/s)
    DIMM Slot #0 8GB DDR4 XMP PC4-19200
    Golden Empire / CL16-16-16 D4-2400
    16-16-16-36 / 2400 MHz / 1.200V
    DIMM Slot #1 8GB DDR4 XMP PC4-19200
    Result summary
    Test Start Time 2020-11-02 13:12:41
    Elapsed Time 3:42:01
    Memory Range Tested 0x0 - 41F380000 (16883MB)
    ECC Polling Enabled
    # Tests Passed 47/48 (97%)
    Lowest Error Address 0x7AF9A3CC (1967MB)
    Highest Error Address 0x7AF9A3CC (1967MB)
    Bits in Error Mask 0000000040000000
    Bits in Error 1
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 7 [Moving inversions, 32-bit pattern] 3/4 (75%) 1
    Test 8 [Random number sequence] 4/4 (100%) 0
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2020-11-02 15:04:39 - [Data Error] Test: 7, CPU: 4, Address: 7AF9A3CC, Expected: BFFFFFFF, Actual: FFFFFFFF
    Yes, it looks like a RAM failure.
    See this page to start with
