Running on 640x480?
  • pjc
    • Sep 2014
    • 7
    Running on 640x480?
    Is there some way to control the graphics resolution used by 5.x and newer? The log says that it detects a console size of 80x25, and then initializes the graphics.
    The graphics mode it selects is 640x480, but the UI appears to be laid out for 800x600, so some of the options are invisible off the bottom of the screen.
    Is there either some way to coax it into switching the video to 800x600 or to fitting the interface in 640x480? (Or to get more diagnostic info as to why the discrepancy?)
    It looks like the default resolution for your system is set to 640x480. We'll look into automatically setting the resolution to a minimum of 800x600 for the next beta release.
