How to know which location of DIMM module error
  • anthoney
    • Oct 2014
    • 17
    I have populate 4 DIMMs at SUPERMICRO H8QGL, when display error message but I can't resolution which DIMM was fail from error report. Due to opition of MAP always fast cancellation, who can teach me how to calculating? how to know DIMM map?
ID:	35164Click image for larger version
    one DIMM is 16GB
    Different CPU & motherboard have different mapping (and it also varies depending on the slots used and number of stick used). So generally, unless you are Intel or AMD, you can't say with any certainty which bytes are mapped to which sticks.
    Just test 1 stick at a time.
    • Enrique2014
      • Oct 2014
      Hi, I run in my computer and appear this. What can I do to solve. ThanksClick image for larger version
        Enrique2014, you are using MemTest86+, which is not our software. The author of MemTest86+ used more or less the same name, so it is confusing.
        We only provide support for the original MemTest86 software.
