memtest results help
  • skillsbybas
    • Jan 2021
    these are my memntest86 results, bear in mind I stopped the test at 13 because I went to sleep and figured the ram was just bad. I've had troubles with my new build since installing windows but I'm new to building pcs so I couldn't figure out for the longest time what was wrong and all the bluescreens have been giving me anxiety. However I also read that errors can be due to other reasons. is anyone able to confirm to me that these errors are due to my ram stick being bad?
    EFI Specifications 2.70
    System
    Manufacturer Gigabyte Technology Co., Ltd.
    Product Name B550 GAMING X V2
    Version Default string
    Serial Number Default string
    BIOS
    Version F11
    Release Date 12/31/2020
    Baseboard
    Version x.x
    CPU Type AMD Ryzen 5 3600XT 6-Core
    CPU Clock 3793 MHz [Turbo: 3793.3 MHz]
    # Logical Processors 12 (6 enabled for testing)
    L1 Cache 12 x 64K (211317 MB/s)
    L2 Cache 12 x 512K (80521 MB/s)
    L3 Cache 1 x 32768K (21689 MB/s)
    Memory 16343M (9715 MB/s)
    DIMM Slot #0 16GB DDR4 XMP PC4-25600
    Kingston / KHX3200C16D4/16GX / 2A4AE375
    16-20-20-39 / 3200 MHz / 1.350V
    Result summary
    Test Start Time 2021-01-20 01:15:49
    Elapsed Time 0:52:25
    Memory Range Tested 0x0 - 440000000 (17408MB)
    ECC Polling Enabled
    # Tests Passed 7/13 (53%)
    Lowest Error Address 0x41AF0C540 (16815MB)
    Highest Error Address 0x43DE4E638 (17374MB)
    Bits in Error Mask 000000000000FF00
    Bits in Error 8
    Max Contiguous Errors 1
    Test # Tests Passed Errors
    Test 0 [Address test, walking ones, 1 CPU] 2/2 (100%) 0
    Test 1 [Address test, own address, 1 CPU] 2/2 (100%) 0
    Test 2 [Address test, own address] 1/1 (100%) 0
    Test 3 [Moving inversions, ones & zeroes] 1/1 (100%) 0
    Test 4 [Moving inversions, 8-bit pattern] 0/1 (0%) 8
    Test 5 [Moving inversions, random pattern] 0/1 (0%) 40
    Test 6 [Block move, 64-byte blocks] 0/1 (0%) 48
    Test 7 [Moving inversions, 32-bit pattern] 0/1 (0%) 39
    Test 8 [Random number sequence] 0/1 (0%) 32
    Test 9 [Modulo 20, ones & zeros] 0/1 (0%) 4
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 1/1 (100%) 0
    Test 13 [Hammer test] 0/0 (0%) 0
    Last 10 Errors
    2021-01-20 01:35:29 - [Data Error] Test: 9, CPU: 6, Address: 420708238, Expected: B7D8532A, Actual: B7D8C62A
    2021-01-20 01:35:29 - [Data Error] Test: 9, CPU: 6, Address: 4207081E8, Expected: B7D8532A, Actual: B7D8C62A
    2021-01-20 01:35:29 - [Data Error] Test: 9, CPU: 6, Address: 4207080A8, Expected: B7D8532A, Actual: B7D8C62A
    2021-01-20 01:35:29 - [Data Error] Test: 9, CPU: 6, Address: 420708058, Expected: B7D8532A, Actual: B7D8C62A
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E638, Expected: CE2E2607, Actual: CE2ED907
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E630, Expected: EE5F7CF1, Actual: EE5F83F1
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E628, Expected: 188D930B, Actual: 188D6C0B
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E620, Expected: 52CB5AD5, Actual: 52CBA5D5
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E618, Expected: 3E0FD2CF, Actual: 3E0F2DCF
    2021-01-20 01:30:38 - [Data Error] Test: 8, CPU: 0, Address: 43DE4E610, Expected: 4BE0A579, Actual: 4BE05A79
    Yes, it is probably bad RAM. See,
