help!?
  • compman
    • Nov 2014
    help!?
    So, I just build my first computer, well, renovated a damaged computer. I decided to make sure everything Is up to spec and downloaded memtest86+ . Being at the end of my journey(almost build my first computer), I was overtaken with excitement and went on a flurry of mishap. I ended up installing one of the downloads(I didn't bother to pick a specific one) into my floppy disk, which Is empty. Now I need to know how to activate/remove It.
    Thanks in advance!
    MemTest86+ is not our software.
    The author of that product used nearly the same name, which makes it confusion.
    You might want to contact the MemTest86+ author for help.
    The original MemTest86 software can be found here.
