Need advice on MemTest86 results --- Fail 5 errors test 8
  • g3b
    I ran the memtest a few days ago with the fail result & 5 errors. Then I ran aida64 premium it throttled after 1.5 min. I would appreciate your thoughts on the results...
    Test Start Time 2021-03-30 18:14:57
    Elapsed Time 3:07:05
    Memory Range Tested 0x0 - 440000000 (17408MB)
    CPU Temperature Min/Max/Ave 32C/41C/37C
    RAM Temperature Min/Max/Ave -/-/-
    # Tests Passed 45/48 (93%)
    Lowest Error Address 0x1FB8AA4C0 (8120MB)
    Highest Error Address 0x34A3CF540 (13475MB)
    Bits in Error Mask 0000000000000080
    Bits in Error 1
    Max Contiguous Errors 1
    CPUs in Error 6, 10
    Test # Tests Passed Errors
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 1/4 (25%) 5
    Test 13 [Hammer test] 4/4 (100%) 0
    Last 10 Errors
    2021-03-30 20:30:45 - [Data Error] Test: 8, CPU: 10, Address: 2B0F30A00, Expected: E29EE41A, Actual: E29EE49A
    2021-03-30 19:59:21 - [Data Error] Test: 8, CPU: 6, Address: 288454C40, Expected: FAF42C2C, Actual: FAF42CAC
    2021-03-30 19:59:00 - [Data Error] Test: 8, CPU: 6, Address: 210ED9CC0, Expected: E4410533, Actual: E44105B3
    2021-03-30 19:08:47 - [Data Error] Test: 8, CPU: 6, Address: 34A3CF540, Expected: 743E0FE5, Actual: 743E0F65
    2021-03-30 19:07:53 - [Data Error] Test: 8, CPU: 6, Address: 1FB8AA4C0, Expected: 95E3C735, Actual: 95E3C7B5
    Certification
    Windows10 (latest edition) cpu 2600x with Noctua cooler, 16gb ram gigabyte aorus b450m 500 m.2 storage
    Thank you,
    g3b
    Looks like the RAM is bad. See,
