Memtest result interpretation
  • Ludovick
    • Dec 2014
    Hello, first of — thanks for the incredible and free test utility, this is what I had to do to figure out the issue with my new hardware.
    However, I'm not clearly sure, on the 4 errors I got by 4 passes of memtest86, they all look like this (only address different):
    Test: 3 Adr: A870CB4C Expected: FFFFFFFF Actual: FFFDFFFF CPU: 0
    Is it RAM or CPU producing error?
    Thanks in advance, have to go to service center tomorrow.
    RAM fails more often than the CPU. CPU faults also tend to have a larger impact on many more addresses.
    So assume it is the RAM at fault initially. Swap the RAM (or remove half of it) and retest.
    • Ludovick
      • Dec 2014
      Hello David, thanks for answering, would transfer the new bought box to service today.
      Been actually receiving tons of errors (memory_management, kernel_security_check_failure, 0x000000D1 etc.), I got a list of at home. The box was restarting spontaneously on some files copy from outer hdd, none of the big software was finished (checksum dll error interruption).
      Since I'm not a hardware enthusiast it's just a one big pain.
      Hopefully they would just swap the RAM for me and it would help.
        Random errors like this are a typical symptoms of RAM faults.
