MemTest86 - Question regarding Dual Channel
  • LapinFou
    • Sep 2021
    Hi folks,
    Somebody gave me an old SuperMicro server (X10SRi-F motherboard). The OS is RedHat 7.
    I desperately try to check if the RAM are correctly populated on the MB by checking if the Dual Channel mode is active or not.
    I recall I was using MemTest86 long times ago on my personal PC to check if the dual channel was active or not (128 bits addressing mode Vs. 64 bits).
    It seems this information is not available on the latest MemTest86.
    Any idea how I could check that the dual channel is enabled using MemTest86?
    BR,
    Seb
    • 337
    MemTest86 does not report if RAM is in dual channel mode or not, and never has done so.
    (it might be something we do in the future, but not at the moment)
    Also, there is no such thing as 128 bit addresses.
    • LapinFou
      • Sep 2021
      Hi Simon,
      Thanks a lot for the answer. I probably got confuse between the 128bits test and the dual channel mode.
      Indeed, it could be a nice enhancement in a future version!
