Memtest86 issue after memory controller line during initial run
  • kenreldo
    • Oct 2021
    Was trying to test new RAM using Memtest86. Ran once fine with no issues, but discovered errors with RAM. Adjusted overclock and tried to run Memtest again, but Memtest would cause the computer to reboot after the "Getting Memory Controller" line every time after. Repeatable issue. Installed old RAM and re-imaged USB, but issue is still occurring. Log attached below. Same CPU/Mobo everything else for each test, only RAM changed.
    Try running MemTest86 without overlock. If it runs okay, then the issue may be that your system is not stable with the values you chosen.
    • kenreldo
      • Oct 2021
      Thanks, I have tried running the MemTest without overclock and the issue persists. The log above is from a test with no overclock.
      • kenreldo
        • Oct 2021
        Issue still persists, any help folks can provide/identify any issues from the log provided?
          • 337
          Try resetting the BIOS to defaults and moving the memory to different slots?
          • kenreldo
            • Oct 2021
            Thanks for the suggestion, I will try. I've seen some other similar posts on this board and updating the blacklist.cfg file was recommended at times. My board is an Asus B350-F Gaming, which I didn't see included. Would adding it help? How would I go about doing that?
              • 337
              You can edit the blacklist.cfg file in '\EFI\BOOT
              Though since it did run previously, I do not think it would help.
