Report Fail Test 8 and Test 13 : How to know waht's wrong?
  • AkaBee
    • Nov 2021
    Hello to all,
    I had some issues while doing the MemeTest86. It appears that it is FAIL. Does any one know how to interpret theses results?
    My bios had the XMP profile with FCLK at 1800mhz.
    Many thanks for your help and support.
    Here below the report:
    Summary
    Report Date 2021-11-01 22:41:46
    Generated by MemTest86 V9.3 Free (64-bit)
    Visit MemTest86.com to Upgrade to Pro
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer Micro-Star International Co., Ltd.
    Product Name MS-7C56
    Version 1.0
    Serial Number To be filled by O.E.M.
    BIOS
    Vendor American Megatrends International, LLC.
    Version 1.60
    Release Date 05/13/2021
    Baseboard
    Product Name MPG B550 GAMING PLUS (MS-7C56)
    Version 1.0
    Serial Number 07C5610_KA1E125950
    CPU Type AMD Ryzen 5 3600 6-Core
    CPU Clock 3600 MHz [Turbo: 4125.5 MHz]
    # Logical Processors 12 (6 enabled for testing)
    L1 Cache 12 x 64K (220961 MB/s)
    L2 Cache 12 x 512K (78137 MB/s)
    L3 Cache 1 x 32768K (33253 MB/s)
    Memory 16326M (18000 MB/s)
    Number of RAM SPDs detected 2
    SPD #0 8GB DDR4 XMP PC4-28700
    Corsair / CMK16GX4M2D3600C18
    18-22-22-42 / 3596 MHz / 1.350V
    SPD #1 8GB DDR4 XMP PC4-28700
    Number of RAM slots 4
    Number of RAM modules 2
    DIMM Slot #0 Empty slot
    DIMM Slot #1 8GB DDR4 PC4-28800
    Unknown / CMK16GX4M2D3600C18 / 00000000
    3600 MHz
    DIMM Slot #2 Empty slot
    DIMM Slot #3 8GB DDR4 PC4-28800
    3600 MHz
    Result summary
    Test Start Time 2021-11-01 19:40:34
    Elapsed Time 2:59:27
    Memory Range Tested 0x0 - 430000000 (17152MB)
    CPU Temperature Min/Max/Ave 36C/54C/46C
    RAM Temperature Min/Max/Ave -/-/-
    # Tests Passed 40/48 (83%)
    Lowest Error Address 0x3FCDDF4 (63MB)
    Highest Error Address 0x41CE2656C (16846MB)
    Bits in Error Mask 0000000000080000
    Bits in Error 1
    Max Contiguous Errors 1
    CPUs that detected memory errors { 0, 2, 4, 6, 8, 10 }
    Bits in Error
    63 0
    Test # Tests Passed Errors
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 0/4 (0%) 173
    Test 13 [Hammer test] 0/4 (0%) 9
    Last 10 Errors
    2021-11-01 22:40:00 - [Data Error] Test: 13, CPU: 0, Address: 3F95D9CB4, Expected: 05170567, Actual: 051F0567
    2021-11-01 22:09:13 - [Data Error] Test: 8, CPU: 4, Address: 3F7EAC274, Expected: 72AFBFC7, Actual: 72A7BFC7
    2021-11-01 22:09:13 - [Data Error] Test: 8, CPU: 10, Address: 3EBBA2354, Expected: 9DC22E3D, Actual: 9DCA2E3D
    2021-11-01 22:09:11 - [Data Error] Test: 8, CPU: 8, Address: 3EC227D74, Expected: EE4A4042, Actual: EE424042
    2021-11-01 22:09:10 - [Data Error] Test: 8, CPU: 0, Address: 3E401F1E4, Expected: CC18EF90, Actual: CC10EF90
    2021-11-01 22:09:06 - [Data Error] Test: 8, CPU: 8, Address: 3BE37D3F4, Expected: CFB3823D, Actual: CFBB823D
    2021-11-01 22:09:03 - [Data Error] Test: 8, CPU: 8, Address: 3BE0B6DF4, Expected: 992A7AE7, Actual: 99227AE7
    2021-11-01 22:09:03 - [Data Error] Test: 8, CPU: 0, Address: 3CD679A74, Expected: 4732B32B, Actual: 473AB32B
    2021-11-01 22:08:59 - [Data Error] Test: 8, CPU: 10, Address: 38908CDF4, Expected: 2D0D4CF9, Actual: 2D054CF9
    2021-11-01 22:08:51 - [Data Error] Test: 8, CPU: 4, Address: 365E2ADB4, Expected: 4957CDB9, Actual: 495FCDB9
    • 337
    Likely the RAM is bad.
    Start with this page for more on troubleshooting:
    • Rachel (PassMark)
      • Nov 2021
      We have just released a video on troubleshooting bad RAM with MemTest86, where we introduce:
      • Common symptoms of memory errors
      • How to test with Memtest86
      • How to analyse for results
      • Potential fixes.
      This should assist with your troubleshooting. You can view the video here: https://www.youtube.com/watch?v=_Oe-efQB4Q0
