The Surface Pro X can‘t run Memtest86
  • yelongnihao
    • Nov 2021
    • 11
    As you can see in the photo,I made a USB flash drive for Memtest86 and it worked on my X86 laptop, but running it on the Surface Pro X stuck on this interface, telling me if it was ARM compatibility or if Microsoft was blocking my CPU information. I remember memtest86 9.0 is compatible with ARM PC, right?
    Hope to find a solution :D
    We have tested MemTest86 in-house with Surface Pro X (with an ARM CPU), so the Surface Pro X should be supported. If you are using V9.0 there have been a couple of releases since, make sure you are running the latest release of MemTest86. If you believe there is still an issue with MemTest86, you can send in the debug logs and we can take a look.
    • yelongnihao
      • Nov 2021
      • 11
      Thank you for your reply. I downloaded the latest memtest from dowload page. It should be version 9.3. I am not sure if it can get log files in my case, I will check later,and send it out.
      • yelongnihao
        • Nov 2021
        • 11
        Or do I need to set some parameters for USB to work properly on the Surface Pro X?
        • yelongnihao
          • Nov 2021
          • 11
          Hi all ,this is my log ,please take a look.
            Thanks for the logs.
            The hang was caused by failing to measure the CPU clock speed properly.
            We made some changes that may fix the issue. We don't have your exact system but you can give this build a try if you like:
            https://www.passmark.com/temp/memtes...b-9.3.1008.zip
            • yelongnihao
              • Nov 2021
              • 11
              Hi it's me again, I am here with you to give me the version of the validation, and found that can enter into the memtest logo interface, but found that I can't move my mouse, computer did not automatically start testing, I tried the mouse, press the keyboard, touchpad, according to the touch screen, all can't move my mouse, seemed to hang in the interface.
              And this is my log, please look at it again,thanks for you all T-T.
              • yelongnihao
                • Nov 2021
                • 11
                • yelongnihao
                  • Nov 2021
                  • 11
                  Guys, I'm still here, waiting for a response T-T
                    We included some additional logging. Can you give this build a try and send the logs as before:
                    https://www.passmark.com/temp/memtes...b-9.3.1009.zip
                    • yelongnihao
                      • Nov 2021
                      • 11
                      Thank you for your reply. I have tried using the version you provided. Please check my log。
                      • Ellick
                        • Dec 2021
                        • 21
                        Hi Richard,
                        I met the same issue as yelongnihao. Could you please share the UEFI and SAM version of Surface Pro X which you have tested in-house? I will compare with mine. Thank you so much.
                          The surface pro X we're using has;
                          UEFI = 3.570.140
                          SAM = 14.509.139
                            Seems that the system hangs when attempting to read keyboard input. This may be a UEFI bug as it doesn't occur on x86 systems.
                            We added an attempted workaround to bypass this issue.
                            Please give this build a try:
                            https://www.passmark.com/temp/memtes...b-9.3.1010.zip
                            • yelongnihao
                              • Nov 2021
                              • 11
                              Hi Keith, I tried it with your version. The result is still the same, still hang in the same interface, caps light is not on, but fn light can be switched.
