Memtest86 Pro Config Question
  • wlittle
    • Jan 2022
    Hey I just got the pro version of Memtest86 Pro. I was wondering if you are able to do a config file where you have a certain number of passes ran lets say 10 and then have the config file do a immediate ram benchmark to check to see if the speeds were affected by temperature and length of test.
    So example:
    run 10 passes
    Benchmark + screenshot
    run 10 passes
    Done
    all this done in a config file so it can be done while I'm not at computer and can be ran over night.
    Thanks for any help.
    While there are a bunch of config file options, there isn't any scripting option like this.
    It should only take around 10min to reach max temperature. But RAM doesn't throttle when it gets hot (many CPUs do however).
    The length of the test won't effect the benchmark results.
