Announcement
No announcement yet.
Problems with MEMTEST86 run on Hard disk
  • Filter
  • Problems with MEMTEST86 run on Hard disk
    First, thank you very much for your excellent software and hard work.
    Because the USB key is broken, I made a fat32 format partition on the hard disk, put the MEMTEST86 V9.2Pro in it, and then ran MEMTEST86, but the error "Unable to open file for writing" appeared, can I solve this problem by configuring MEMTEST86?
  • #2
    This may have been fixed in V9.3.
    PassMark MemTest86 - Version History
    • Fixed report/log files not being saved correctly for non-standard USB flash drive installs
    Can you give the latest build a try.
