Interesting mem issues pass/fail depending on order or parallel
  • memoryerror
    • Jan 2022
    I have an interesting problem where memtest fails with all 4 sticks provided that it is run in parallel mode (but only on CPU 0), in single mode it passes. I also note that if I have modules with serial numbers ending in 3, 5 in one order memtest passes in parallel mode while in the other order mem test fails. The memory has been tested on some other (slow rigs) and passes. Help?
    AMD 5950x
    G.Skill Ripjaws v 128GB ddr4 3200Mhz Cl16 memory 4x32GB sticks
    gigabyte aero g 570s F3d BIOS
    For all of these tests XMP is enabled (I hope, the store I bought the memory from did the tests on the 3300x and 5800x).
    The memory itself has been tests on the following and passes:
    Motherboard CPU Test type memory speed MB/s Modules tested at a time Pass/fail Links
    ROG STRIX X570-I GAMING 3300X Parallel (All CPUs) 17786 2 Pass Set 1
    Set 2
    Ryzen 7 5800x Parallel (All CPUs) 38805 4 Pass results
    x570s aero g Ryzen 9 5950x Parallel (All CPUs) 40535 2 Fail results Modules order 3 then 5
    x570s aero g Ryzen 9 5950x Parallel (All CPUs) 40422 2 Pass Results Modules order 5 then 3
    x570s aero g Ryzen 9 5950x Parallel (All CPUs) 41551 4 Failed Results Test 6 CPU 0
    x570s aero g Ryzen 9 5950x Single: CPU # 0 41551 4 Pass Results
    x570s aero g Ryzen 9 5950x Parallel (All CPUs) 41551 4 Fail Results Much older run
    Is the memory at fault here or is it perhaps the CPU or motherboard?
    What other tests should I run to work this out?
    • 337
    Could any of the three, probably try replacing the memory first?
    There are some troubleshooting steps here
    • memoryerror
      • Jan 2022
      It looks like when running test 6 only, only memory module with SN ending in 3 fails. The other 4 pass test 6. Interestingly module ending in 3 failed on the 3rd iteration.
      • memoryerror
        • Jan 2022
        i notice that it is always CPU 0 that catches the issues, but the issues only show under parallel mode. Is passmark choosing the section of ram to test randomly?
          From version 9.0, after each pass we reverse the order of the memory regions allocated to each CPU core.
          So if a single bit/byte of RAM is bad AND it is detected as bad in each pass, then the CPU cores should not be the same from one pass to the next.
