Memtest86 freez for a couple second after finished test.
  • asia23fab
    • Apr 2015
    • 13
    Hello. Is this normal? After 100% finished each test program TIME just stops for a couple of seconds. And after few seconds time is running again on beggining on new test.
    I explain:
    When before test is 0% there is a freez , time just stops. And after few seconds time is running again and test is starting running.
    It is normal when time freez for a couple of second on 0% test?
    It locks up on 0% for 5 second and its running again.
    Time doesn't actually stop.
    But there might be periods (especially on slower machines) where the screen doesn't update for a second or two.
    • asia23fab
      • Apr 2015
      • 13
      It locks up ( time just freez ) on 0% for 5 second and its running again. Its normal? When i am on 0% test time stops for a few seconds and then its working again.
      I have 4790k and memory:
      HyperX 2x4GB 1600MHz DDR3 Non-ECC CL9 DIMM Plug n Play (KHX1600C9D3P1K2/8G)
        If you have a slow USB drive, it may cause the system to pause at the beginning of each test while the logs are being written. If you post or send us the MemTest86.log file we may be able to see what's going on before the tests are started.
