Problem with memtest displaying the test window.
  • arcyzm
    • May 2015
    Hello.
    I tried to find solution for this problem and I couldnt find anything on this forum.
    When I start memtest86 v.6 from usb ( I use 3.0 extreme sandisk ) I have no problems with menu but when I start the test the whole table is very small and I can see only half of it.
    I run GTX 970 on 1920x1080 res with 22inch 1080p monitor. Connected via DVI.
    MOBO: MSI Z97 Gaming 7. RAM: G-skill TridentX 8GB 2400MHz. CPU: i7 4790k.
    Thank you for help.
    That's an odd place to display the test window.
    This looks like a bug in the BIOS firmware as it is responsible for determining the exact position for the text to be drawn on the screen. MemTest86 only specifies the relative coordinates which the firmware uses to determine the absolute coordinates on the screen.
    I would check to see if there is an updated BIOS available from MSI.
