failed test 8 and 13
  • jjose
    • Dec 2022
    Hello, I had multiple blue screen errors and after days of trying to see what was wrong, I did the memtest86 for ram and found that tests 8 and 13 were not passed, is this a faulty stick or XMP being faulty?
    Report Date 2022-12-03 16:48:53
    Generated by MemTest86 V10.0 Free (64-bit)
    Visit MemTest86.com to Upgrade to Pro
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer Micro-Star International Co., Ltd.
    Product Name MS-7C91
    Version 1.0
    Serial Number To be filled by O.E.M.
    BIOS
    Vendor American Megatrends International, LLC.
    Version 2.10
    Release Date 05/25/2022
    Baseboard
    Product Name MAG B550 TOMAHAWK MAX WIFI (MS-7C91)
    Version 1.0
    Serial Number 07C9114_M21E869028
    CPU Type AMD Ryzen 9 5900X 12-Core
    CPU Clock 3700 MHz
    # Logical Processors 24 (16 enabled for testing)
    L1 Cache 24 x 64K (273762 MB/s)
    L2 Cache 24 x 512K (115613 MB/s)
    L3 Cache 1 x 65536K (49670 MB/s)
    Memory 32710M (45728 MB/s)
    Number of RAM SPDs detected 2
    SPD #0 16GB DDR4 XMP PC4-28700
    Team Group Inc. / TEAMGROUP-UD4-3600 / 01048E63
    18-22-22-42 / 3596 MHz / 1.350V
    SPD #1 16GB DDR4 XMP PC4-28700
    Team Group Inc. / TEAMGROUP-UD4-3600 / 01048E52
    Number of RAM slots 4
    Number of RAM modules 2
    DIMM Slot #0 Empty slot
    DIMM Slot #1 16GB DDR4 PC4-28800
    Unknown / TEAMGROUP-UD4-3600 / 01048E63
    3600 MHz
    DIMM Slot #2 Empty slot
    DIMM Slot #3 16GB DDR4 PC4-28800
    Unknown / TEAMGROUP-UD4-3600 / 01048E52
    3600 MHz
    Result summary
    Test Start Time 2022-12-03 12:30:01
    Elapsed Time 4:03:24
    Memory Range Tested 0x0 - 830000000 (33536MB)
    CPU Temperature Min/Max/Ave 31C/66C/48C
    RAM Temperature Min/Max/Ave -/-/-
    # Tests Passed 41/48 (85%)
    Lowest Error Address 0x10229D7C (258MB)
    Highest Error Address 0x7D477DB7C (32071MB)
    Bits in Error Mask 0000000011080000
    Bits in Error 3
    Max Contiguous Errors 1
    CPUs that detected memory errors { 0, 1, 3, 5, 6, 7, 9, 10, 14 }
    Bits in Error
    . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . x . . . x . . . . x . . . . . . . . . . . . . . . . . . .
    63 0
    Test # Tests Passed Errors
    Test 7 [Moving inversions, 32-bit pattern] 4/4 (100%) 0
    Test 8 [Random number sequence] 0/4 (0%) 18
    Test 13 [Hammer test] 1/4 (25%) 9
    Last 10 Errors
    2022-12-03 16:33:20 - [Data Error] Test: 13, CPU: 0, Address: 3EB48003C, Expected: 1C3DA6EB, Actual: 1D3DA6EB
    2022-12-03 16:32:24 - [Data Error] Test: 13, CPU: 0, Address: 104F052BC, Expected: 5B26BC5C, Actual: 5A26BC5C
    2022-12-03 16:29:09 - [Data Error] Test: 13, CPU: 0, Address: 762F0F27C, Expected: 4F617EA5, Actual: 4E617EA5
    2022-12-03 16:27:10 - [Data Error] Test: 13, CPU: 0, Address: 6ACF9D7FC, Expected: 003CEF9E, Actual: 103CEF9E
    2022-12-03 15:52:50 - [Data Error] Test: 8, CPU: 3, Address: 67054A93C, Expected: 5B63D044, Actual: 4B63D044
    2022-12-03 15:51:48 - [Data Error] Test: 8, CPU: 7, Address: 2639A79FC, Expected: A5CF147E, Actual: B5CF147E
    2022-12-03 15:51:35 - [Data Error] Test: 8, CPU: 6, Address: 1A48342BC, Expected: 825DB6F2, Actual: 925DB6F2
    2022-12-03 14:46:54 - [Data Error] Test: 8, CPU: 6, Address: 7D462A8BC, Expected: BB647BDE, Actual: BB6C7BDE
    2022-12-03 14:46:51 - [Data Error] Test: 8, CPU: 6, Address: 7D477DB7C, Expected: 6FBECAB0, Actual: 7FBECAB0
    2022-12-03 14:46:36 - [Data Error] Test: 8, CPU: 1, Address: 6C1FB2EFC, Expected: 39B348C1, Actual: 38B348C1
    See this page to start with
