MemTest LOG (how to read?)
  • cedrikpaul
    • May 2023
    Hello together!
    I am a "NOOB" and so i like to ask some "PROs" for help .....
    Since 1 month i have problems with playing games on my PC .... if i play some games which needs a lot of "POWER" PC gets frozen....(but i cant close it via TASK MANAGER i have restart the PC manually (powerBUTTON) .....
    so i made a MEMTEST to check.....but i cant read the LOG (i am a "NOOB") *haha* .....
    i would be so THANKFULL if anyone could tell me whats the LOG tells about my HARDWARE..... thx a lot
    Kind Regards
    Dave
  • cedrikpaul
    • May 2023
    his is the summary
      You posted the debug log. Which is really only for debugging MemTest86 itself. You aren't meant to understand the content. Even we barely understand it.
      There is another HTML report at the end with more readable data.
      Here is an example of that HTML report
      https://forums.passmark.com/filedata/fetch?id=55035
      Having said that, your debug log did contain a bunch of RAM errors.
      They look like this.
      [MEM ERROR - Data] Test: 7, CPU: 0, Address: 32738C10C, Expected: 00000008, Actual: 00000088
      So there is some hardware fault.
      See this page to start with
