Accessing report and screen shots?
  • RichS
    • Jun 2023
    • 8
    Apologies for what is probably a basic question, but - how do I access the html log file and the F12 screen shots I captured after testing? If I reboot my machine and try to access the USB drive, it asks me to format it, and says it doesn't contain a recognized file system.
    I tried formatting and then going through the entire boot-disk creation process again, running one test, saving the result again, along with one screen shot. And rebooting yielded the same result as above.
    How do I access files saved on the USB drive if it's not formatted so it can be read by Windows? I'm using the latest release of Windows10.
    There are two partitions on the USB drive (for historic compatibility reasons with older BIOSs).
    You are looking at the wrong partition.
    There should be 2nd one that will pop up with a drive letter.
    Ignore the message about formatting.
