Other ideas after successful test?
  • RichS
    • Jun 2023
    • 8
    I finally got around to adding another 16GB to my machine, so 32GB total, as memory has become quite cheap. But ever since I installed the memory, the machine crashes every 12 hours or so. It just shuts down with no warnings and no other symptoms - just power off.
    I ran memtest86 three times - about 5 hours each time - with no errors reported. The only issue I saw was selecting the Test 14 (iirc) marked as in beta test, one one other test cycle. My machine froze at 52 minutes, so about when it would be running the end of the first cycle. It didn't shut down, just froze on the screen. The timer was stuck at 52 minutes and the system clock was frozen, about 2 hours earlier than the actual time. Keyboard, mouse, etc. did nothing - I had to hard reset.
    Attached is the report and log file (can I really not upload the default html version?) The only thing that looks even remotely odd is that the memory JEDEC and SMBIOS Profile says either 1.5V or 1.35-1.5V but the "RAM Configuration" says 1.185V. But I've never overclocked, over-volted, under-volted, etc. - it's configured just as I bought it years ago.
    I tried swapping memory slots - moving them in pairs to the alternate positions, but it made no difference - crashed again in a few hours.
    Any ideas, other than tossing $25 of memory, sticking with 16GB, and a lesson learned?​
    Test #14 (DMA) writes a lot of data to the USB drive that you used for booting.
    However we found that USB drives are way less reliable than RAM. Way way less. So more often than not, faults in the USB drive were exposed before RAM faults were exposed.
    So that might be the case here as well, you might have a bad USB drive.
    • leclod
      • Jun 2023
      • 11
      I'd try to run the new kit only, to see if it maybe crashes on its own.
      (Care to share some specs ?)
      • RichS
        • Jun 2023
        • 8
        I've pulled the new memory and the old kit has run fine for a bit over 3 days, so it doesn't appear that something broke somewhere else while adding the memory.
        I'll swap to the new kit at the end of the day and see if it runs on its own also.
        The USB drive is probably at least 10 years old, so if that's a potential weak point, then it's likely what happened, so I'll ignore that failure.
        I'm not sure I have more specs than what is in the log/report - what else is useful?
        2 sticks of each - Samsung is the original, Crucial is the new - part number specified on their website.
        SPD #0 8GB DDR3 2Rx8 PC3-12800
        Vendor Part Info Samsung / M378B1G73DB0-CK0 / 23DA187C
        JEDEC Profile 1600MT/s 11-11-11-28 1.5V
        SPD #1 8GB DDR3 2Rx8 PC3-12800
        Vendor Part Info Crucial Technology / CT102464BD160B.M16 / E9000022
        JEDEC Profile 1600MT/s 11-11-11-28 1.5V, 1.35V
        Same with PC specs:
        System
        Manufacturer ASUSTeK COMPUTER INC.
        Product Name G10AJ
        Version System Version
        Serial Number F2PDCG0017YE
        BIOS
        Version 0304
        Release Date 06/05/2014
        Baseboard
        Product Name G10AJ
        Version Rev X.0x
        Serial Number 150137396500329
        CPU Type Intel Core i7-4790 @ 3.60GHz
        CPU Clock 3592 MHz [Turbo: 3791.2 MHz]
        # Logical Processors 8 (4 enabled for testing)
        L1 Cache 4 x 64K (183844 MB/s)
        L2 Cache 4 x 256K (57071 MB/s)
        L3 Cache 8192K (41465 MB/s)
        Memory 32728M (19077 MB/s)
        RAM Configuration DDR3 1600MT/s / 1.185V
        • RichS
          • Jun 2023
          • 8
          New memory also has run fine for 36+ hours - I never got more than 10-12 hours without crashing with all 4 sticks in.
          I'll try interleaving slots, but have little faith that will make a difference. An ideas? Or do I just throw the new memory away/in a drawer?
          • leclod
            • Jun 2023
            • 11
            What do you mean interleaving ? of course you should interleave those 2 kits
              Mixing different sticks of RAM with different specs is never ideal. There are a lot of other timing values than those advertised on the packet.
              See RAMMon for a complete dump of the RAM specs.
              The BIOS is forced to try and find a collection of settings / voltage / timings that will work with both sticks. Sometimes this results in a marginal result. At the very least a situation that was never tested by the motherboard and CPU vendor.
              Maybe it is time to start bumping up the voltage in BIOS?
              Or buy two more of the exact same Crucial sticks?
              Hard to know if the problem is with the motherboard not being able to deal with 4 sticks (in any combination) or the problem is due to slightly different RAM specs between the sticks. Needs more testing.
              • RichS
                • Jun 2023
                • 8
                Well, it's been a week with the mixed positions so I'm going to call it good. PassMark PerformanceTest numbers are about identical to a year ago (other than Available RAM) and BurnInTest has run for billions/trillions of transactions, and several hours.
                My engineering brain is tempted to swap them again to validate, but I'll just leave it as is.
                Weird.
                • leclod
                  • Jun 2023
                  • 11
                  What do you mean with mixed ?
                  You have 2 channels, one in slot 1 and 3, the second in slot 2 and 4.
                  You should populate those 2 channels identically.
                  • RichS
                    • Jun 2023
                    • 8
                    By interleave I mean do not put the original memory in slots 1 and 3, where they originally were, and put the new memory in slots 2 and 4, as would be logical, but is also what caused it to crash regularly.
                    Instead, put the original memory in slots 1 and 2 and the new memory in slots 3 and 4, so each channel has one stick each of old and new memory (i.e. "mixed").
                    2+ weeks now and all is fine, as was all bench-marking and stress testing, as previously noted.
