Questionable code in cpu_type() in versions 6.x and 4.x.
  • Chip Programmer
    • Sep 2015
    One of the first condition checks in the function that tries get the processor identification string, there is a bug in the code. The condition check looks for a 0x0F in the first byte of the CPU Vendor string where one would expect to find "GenuineIntel". What the function wants to do is to identify Intel Pentium 4 type processors, but the condition check should be inside the Intel section, and should be looking at the CPUID value rather than the first byte of the Vendor string.
    Furthermore, the same function that picks the "586" string is lacking "break" instructions in the switch statement. This means that although the function might think it is choosing "586", or "686", the actual string chosen is "Unidentified Processor".
    We are not aware of any instances of mis-identification of real CPUs.
    Do you have a specific example of a CPU model that returns the wrong identification.
    • Chip Programmer
      • Sep 2015
      Here is cpy_type() from the 4.x source:
      * Find CPU type
      void cpu_type(void)
      <snipped>
      /* Unknown processor */
      default:
      /* Make a guess at the family */
      switch(cpu_id.vers.bits.family) {
      case 5:
      cprint(0, COL_MID, "586");
      case 6:
      cprint(0, COL_MID, "686");
      default:
      cprint(0, COL_MID, "Unidentified Processor");
      From the above code snippet, it is quite obvious that "break" statements are missing after the cprint() function calls. If the CPUID value is from family 5, then the first case statement will fall through to the end.
      For the other issue I noted, I'll have to show you the disassembled code to prove my point. However, do us all a favor and pass this thread to the developer(s) so the code can be repaired.
      Even the 4.x version of cpu_type() has a problem dealing with Intel versus Transmeta processors.
      A simple review of the source would tell us/you that.
      Last edited by Chip Programmer; Sep-28-2015, 03:18 PM. Reason: Reformat the code snippet for indentation.
        Thanks for pointing the bugs out.
        As v4.x is open source, we are open to accepting source code patches and incorporating into our code base. So feel free to submit any fixes to any bugs you may have found.
        As David mentioned, it would be good to see a specific example which shows the wrong identification, such as a screenshot of the trace (in v4) or the MemTest86.log file (in v6).
        • Chip Programmer
          • Sep 2015
          Here is some C code that represents what I found in the 6.2.0 EFI binary.
          Code:
          void cpu_type(void)
              DWORD myEAX;
              DWORD myECX;
              DWORD myEDX;
              char *pProcessorString;
              pProcessorString = NULL;
              myEAX = szCPU_VendorId[0];
              myEDX = 0x0F;
              // This first condition is not possible.  It should be located lower, where Intel CPUs are checked.
              switch( myEAX )
              case 0x0F:                                      // szCPU_VendorId[0] == 0x0F?
                  myEAX = dCpuidValue;
                  myEAX >>= 4;
                  myEAX &= myEDX;
                  switch( myEAX )
                  case 0:
                  case 1:
                  case 2:
                      if (dCacheSize == 128)
                          pProcessorString = "Celeron";
                      else
                          pProcessorString = "Pentium 4";
                      break;
                  case 3:
                  case 4:
                      if (dCacheSize == 256)
                          pProcessorString = "Celeron (0.09)";
                      else
                          pProcessorString = "Pentium 4 (0.09)";
                      break;
                  case 6:
                      pProcessorString = "Pentium D (65nm)";
                      break;
                  default:
                      pProcessorString = "Unknown Intel";
                      break;
                  break;
              case 'A':   // szCPU_VendorId[0] == 'A'?
                  myECX = myEAX;
                  myECX >>= 8;
                  myECX &= myEDX;
                  switch( myECX )
                  case 4:
                      myEAX >>= 4;
                      myEAX &= myEDX;
                      switch( myEAX )
                      case 3:
                          pProcessorString = "AMD 486DX2";
                          break;
                      case 7:
                          pProcessorString = "AMD 486DX2-WB";
                          break;
                      case 8:
                          pProcessorString = "AMD 486DX4";
                          break;
                      case 9:
                          pProcessorString = "AMD 486DX4-WB";
                          break;
                      case 14:
                          pProcessorString = "AMD 5x86-WT";
                          break;
                      case 15:
                          pProcessorString = "AMD 5x86-WB";
                          break;
                      break;
                  case 5:
                      myEAX >>= 4;
                      myEAX &= myEDX;
                      switch( myEAX )
                      case 0:
                      case 1:
                      case 2:
                      case 3:
                          pProcessorString = "AMD K5";
                          break;
                      case 6:
                      case 7:
                          pProcessorString = "AMD K6";
                          break;
                      case 8:
                          pProcessorString = "AMD K6-2";
                          break;
                      case 9:
                          pProcessorString = "AMD K6-III";
                          break;
                      case 13:
                          pProcessorString = "AMD K6-III+";
                          break;
                      break;
                  case 6:
                      myEAX >>= 4;
                      myEAX &= myEDX;
                      switch( myEAX )
                      case 1:
                          pProcessorString = "AMD Athlon (0.25)";
                          break;
                      case 2:
                      case 4:
                          pProcessorString = "AMD Athlon (0.18)";
                          break;
                      case 6:
                          if (dCacheSize == 64)
                              pProcessorString = "AMD Duron (0.18)";
                          else
                              pProcessorString = "Athlon XP (0.18)";
                          break;
                      case 8:
                      case 10:
                              pProcessorString = "AMD Duron (0.13)";
                          else
                              pProcessorString = "Athlon XP (0.13)";
                          break;
                      case 3:
                      case 7:
                          pProcessorString = "AMD Duron";
                          break;
                      break;
                  break;
              case 'C':   // szCPU_VendorId[0] == 'C'?
                  if (szCPU_VendorId[1] == 'e')
                      myECX = dCpuidValue;
                      myEAX = myECX;
                      myEAX >>= 8;
                      myEAX &= myEDX;
                      if (myEAX == 5)
                          pProcessorString = "Centaur 5x86";
                      else
                      if (myEAX == 6)
                          myEAX = myECX;
                          myEAX >>= 4;
                          myEAX &= myEDX;
                          if (myEAX == 0x0A)
                              pProcessorString = "VIA C7 (C5J)";
                          else
                          if (myEAX == 0x0D)
                              pProcessorString = "VIA C7 (C5R)";
                          else
                          if (myEAX == 0x0F)
                              pProcessorString = "VIA Isaiah (CN)";
                          else
                          if ((myECX & 0x0F) < 8)
                              pProcessorString = "VIA C3 Samuel2";
                          else
                              pProcessorString = "VIA C3 Eden";
                  else
                      myECX = myEAX;
                      myECX >>= 8;
                      myECX &= myEDX;
                      if (myECX == 0x05)
                          myEAX >>= 4;
                          myEAX &= myEDX;
                          if (myEAX == 0)
                              pProcessorString = "Cyrix 6x86MX/MII";
                          else
                          if (myEAX == 4)
                              pProcessorString = "Cyrix GXm";
                      else
                      if (myECX == 6)
                          myECX = myEAX;
                          myECX >>= 4;
                          myECX &= myEDX;
                          switch( myECX )
                          case 6:
                              pProcessorString = "Cyrix III";
                              break;
                          case 7:
                              if ((myEAX & 0x0F) < 8)
                              else
                                  pProcessorString = "VIA C3 Ezra-T";
                              break;
                          case 8:
                              break;
                          case 9:
                              pProcessorString = "VIA C3 Nehemiah";
                              break;
                  break;
              case 'G':
                  if (szCPU_VendorId[7] == 'T')   // "GeniuneTMx86" ?
                      myEAX >>= 8;                // Get CPUID family value
                      myEAX &= myEDX;
                      if (myEAX == 5)             // CPUID == 0x000005xx?
                          pProcessorString = "TM 5x00";
                      else
                      if (myEAX == 15)
                          pProcessorString = "TM 8x00";
                  else
                      myECX = myEAX;              // Only other supported CPU whose VendorID string starts with 'G' is GenuineIntel.
                      myECX >>= 8;                // Get CPUID family value
                      myECX &= myEDX;
                      if (myECX == 4)             // 80486 processor?
                          myEAX >>= 4;            // Is 80486.  Get the model value.
                          myEAX &= myEDX;
                          switch( myEAX )
                          case 0:
                          case 1:
                              pProcessorString = "Intel 486DX";
                              break;
                          case 2:
                              pProcessorString = "Intel 486SX";
                              break;
                          case 3:
                              pProcessorString = "Intel 486DX2";
                              break;
                          case 4:
                              pProcessorString = "Intel 486SL";
                              break;
                          case 5:
                              pProcessorString = "Intel 486SX2";
                              break;
                          case 6:
                              goto cpu_type_done;
                          case 7:
                              pProcessorString = "Intel 486DX2-WB";
                              break;
                          case 8:
                              pProcessorString = "Intel 486DX4";
                              break;
                          case 9:
                              pProcessorString = "Intel 486DX4-WB";
                              break;
                      else
                          myECX &= 0xFFFFFFFB;    // Turn off bit 2 of the CPUID family value
                          switch( myECX )
                          case 5:
                              myEAX >>= 4;
                              myEAX &= myEDX;
                              if (myEAX <= 3)
                                  pProcessorString = "Pentium";
                              else
                              if (myEAX == 4)
                                  pProcessorString = "Pentium-MMX";
                              else
                              if (myEAX == 7)
                              else
                              if (myEAX == 8)
                              break;
                          case 6:
                              myEAX >>= 4;
                              myEAX &= myEDX;
                              switch( myEAX )
                              case 0:
                              case 1:
                                  pProcessorString = "Pentium Pro";
                                  break;
                              case 3:
                              case 4:
                                  pProcessorString = "Pentium II";
                                  goto cpu_type_done;
                              case 5:
                                  if (dCacheSize == 0)
                                  else
                                  break;
                              case 6:
                                  else
                                  break;
                              default:
                                  break;
                              break;
                          case 7:
                          case 8:
                          case 11:
                              else
                                  pProcessorString = "Pentium III";
                              break;
                          case 9:
                              if (dCacheSize == 512)
                                  pProcessorString = "Celeron M (0.13)";
                              else
                                  pProcessorString = "Pentium M (0.13)";
                              break;
                          case 10:
                              pProcessorString = "Pentium III Xeon";
                              break;
                          case 12:
                              pProcessorString = "Atom (0.045)";
                              break;
                          case 13:
                              if (dCacheSize == 1024)
                                  pProcessorString = "Celeron M (0.09)";
                              else
                                  pProcessorString = "Pentium M (0.09)";
                              break;
                          case 14:
                              pProcessorString = "Intel Core";
                              break;
                          case 15:
                                  pProcessorString = "Pentium E";
                              else
                                  pProcessorString = "Intel Core 2";
                              break;
                  break;
              default:
                  myEAX >>= 8;           ; // Get CPUID family value
                  myEAX &= myEDX;
                  switch( myEAX )
                  case 5:
                      pProcessorString = "586";
                      //break; // This is missing.
                  case 6:
                      pProcessorString = "686";
                  default:
                      pProcessorString = "Unidentified Processor";
                      break;
                  break;
          cpu_type_done:
              return;
          • Chip Programmer
            • Sep 2015
            Now here is your 6.2.0 EFI binary after disassembly, with some comments.
            Code:
            ; =============== S U B R O U T I N E =======================================
            ; Attributes: bp-based frame
            cpu_type        proc near
            var_C0          = byte ptr -0C0h
            var_40          = byte ptr -40h
                            push    ebp
                            mov     ebp, esp
                            sub     esp, 0C0h
                            cmp     ds:dMaxExtendedCpuidValue, 80000004h
                            jb      short loc_7EE07
                            mov     eax, offset szCPU_BrandId
                            lea     ecx, [ebp+var_40]
                            call    sub_8266D
                            lea     eax, [ebp+var_40]
                            push    eax
                            call    sub_7ED04
                            pop     ecx
                            push    eax
                            push    offset aA_0     ; "%a"
                            lea     eax, [ebp+var_C0]
                            push    80h ; '€'
                            push    eax
                            call    sub_8293A
                            add     esp, 10h
                            jmp     loc_7F2E2
            loc_7EE07:
                            movsx   eax, ds:szCPU_VendorId
                            push    0Fh
                            pop     edx             ; EDX = 0x0F, for saving nibble data
                            sub     eax, edx
                            jz      checkIntelPentium4 ; case (szCPU_VendorId[0] == 0x0F)
                            sub     eax, 32h
                            jz      checkAMD_Processors ; case (szCPU_VendorId[0] == 'A')
                            dec     eax
                            dec     eax
                            jz      checkViaCentaurProcessor ; case (szCPU_VendorId[0] == 'C')
                            sub     eax, 4
                            mov     eax, ds:dCpuidValue
                            jz      short checkIfIntelOrTransmeta ; case (szCPU_VendorId[0] == 'G')
                            shr     eax, 8          ; default (szCPU_VendorId[0] == unknown vendor id string)
                                                    ; Get CPUID Family value into AL
                            and     eax, edx        ; Keep only the Family value
                            sub     eax, 5
                            jz      short cpu_type_choose_586 ; case (Family value == 5)
                            dec     eax
                            jz      short cpu_type_choose_686 ; case (Family value == 6)
                            jmp     short cpu_type_choose_UnidentifiedProcessor ; case (Family value == unknown)
            cpu_type_choose_586:
                            mov     eax, offset a586 ; "586"
                            mov     ecx, esi
                            call    cprint
            cpu_type_choose_686:
                            mov     eax, offset a686 ; "686"
                            mov     ecx, esi
                            call    cprint
            cpu_type_choose_UnidentifiedProcessor:
                            mov     eax, offset aUnidentifiedPr ; "Unidentified Processor"
                            jmp     loc_7F2E2
            checkIfIntelOrTransmeta:
            <snipped>
            At the label loc_7EE07, the assembly code loads EDX register with 0x0F for nibble manipulation of the CPUID value. At the same time, EAX register is loaded with the first character of the CPU Vendor ID string, sign extended from AL into EAX.
            The first instruction after these two registers are loaded is to check if the first character of the CPU Vendor ID string is equal to 0x0F, and perform some actions if this is true. These actions are intended to identify various Intel Pentium IV processors.
            This comparison in assembly code is the first "case" statement after a "switch" statement. The second major comparison in assembly code is to look for the letter 'A' in the first character of the CPU Vendor ID string, believing this to be for AuthenticAMD and to perform AMD processor identification. The first comparison is for the letter 'C', which represents "CentaurHauls" and "CyrixInstead" Vendor ID strings. The assembly code continues, but you should get the picture that the "case 15:" is misplaced.
              Thanks for the disassembly analysis. We were able to locate the bug in the code.
              It looks like there was a misplaced bracket in the 'Intel' case, in the following v4 code.
              Code:
              case 6:
                          switch(cpu_id.vers.bits.model) {
                          case 0:
                          case 1:
                              cprint(0, COL_MID, "Pentium Pro");
                              break;
                          case 3:
                          case 4:
                              cprint(0, COL_MID, "Pentium II");
                              break;
                          case 5:
                              if (l2_cache == 0) {
                                  cprint(0, COL_MID, "Celeron");
                              } else {
                              break;
                          case 6:
                                if (l2_cache == 128) {
                                } else {
                              } // This should not be here
                              break;
              This would most likely affect users of v4 (BIOS) more than v6 (UEFI) due to the fact that systems with UEFI would likely be using a newer CPU with a brand ID string, without the need to go through the switch/case mess. Nevertheless, this has been fixed for the next release.
              Thanks for your time and effort.
