memtest failure on test 8 and test 9
  • avi_shake
    • Jul 2024
    My RIG:
    RAM: XPG 6000MHz 16 GB (1 stick)
    CPU: Ryzen 5 7600x
    GPU: RTX 3080
    For last one week I am getting frequent BSOD while playing games.
    Leading to restart while playing games.
    I checked it to be BSOD error as per Event Viewer.
    So, I ran a memtest on my RIG.
    Got memtest failure on test 8 and 9.
    RAM s the culprit?
    Last 10 errors
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 4, Address: 3455FBC08, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 0, Address: 356436588, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 8, Address: 34FC3CF88, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 2, Address: 3432CF9C8, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 2, Address: 343275D88, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 10, Address: 352028608, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 4, Address: 345E10848, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 6, Address: 34B9FD3C8, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 8, Address: 34DFD3948, Expected: D99A122A, Actual: C99A122A
    2024-07-15 02:28:14 - [Data Error] Test: 9, CPU: 6, Address: 349CFA208, Expected: D99A122A, Actual: C99A122A
    • 11127
    Yes very likely it is bad RAM.
    See this page
    If you do replace the RAM, use either 2 x 8GB or 2 x 16GB. The performance will be better than 1 stick.
