Does this ram speed test look right?
  • Dr3deez
    • Sep 2024
    I am trying to diagnose a slowdown after some time in Resolve. The main ram test had 0 errors. I really don't know what I'm looking at so just seeing if this looks ok or if there is an obvious issue. Corsair Dominator Platinum 24 GB (3 x 8 GB) DDR4-3000 CL15
    24 GB (3 x 8 GB)
    What CPU do you have? Having three sticks for most CPUs is sub-optimal as you can't use dual channel mode.
    Using 2 or 4 is better. (Except for a few rare CPUs with tri-channel support).
    • Dr3deez
      • Sep 2024
      i7-8700k
      I know it can be sub-optimal, but it wouldn't cause a render speed of 6fps to suddenly go to 1fps 20 or 30 minutes in right? Test looks good? I do have 2 new 16gb sticks I will probably swap in to see if it happens to fix the issue soon. It is probably program related, but trying to rule everything out.
        Graph above looked OK (except it might be better with dual channel).
        If you are looking for a system wide benchmark, PerformanceTest is better.
