RAM fails as a pair, not individually - how to rule out Motherboard or CPU fault
  • Zeto
    • Sep 2024
    Hey all!
    I would like some help with diagnosing a Memory issue that popped up for me very recently. After multiple BSODs and various program crashes that seemed to link back to faulty RAM, I ran memtest to find multiple failures in Tests 7 and 13, consistently throughout all passes.
    After further investigation;
    A2 B2 XMP Enabled - Fail
    A2 B2 Stock - Pass
    A2 Either Stick Single, XMP Enabled - Pass
    B2 Either Stick Single, XMP Enabled - Pass
    A1 B1 XMP Enabled - No Post (as expected on this Motherboard)
    A1 B1 Stock - Pass
    Since my Sticks only fail together, and not alone, I'm second guessing on what is actually causing this issue. My system has been running issue free for over a year now - these problems have only started popping up after I cleared my CMOS to fix an (I hope) unrelated issue (USB PD in S5 wouldn't turn off - this fixed itself after clearing the CMOS).
    Attached is the log of the failing test.
    Would really appreciate some insights on this issue, thanks in advance
    Specs are in the log anyway I assume, but here:
    Motherboard: ASRock x570 Steel Legend
    CPU: AMD Ryzen 5 5600x (no Overclocking or Undervolting of any kind)
    RAM: Corsair Vengeance RGB Pro 3600MHz cl18 2x16gb
    Using two sticks will place the RAM into dual channel mode and change the access patterns. So different behaviour isn't all that unusual.
    See also
    https://www.memtest86.com/troublesho...htm#consistent
    As changing the RAM is easy, try that first.
    • Zeto
      • Sep 2024
      I was hoping that it was maybe just a BIOS config issue or something easy to fix haha. Guess I'm RMAing this kit. I'll update the thread if the issue persists with new RAM. Thanks!
