Currently at 347'000 errors and counting
  • NoPleaseNotTheRAM
    • Feb 2016
    Just wanted to know if this could be for real or if there's some error with the software? I'm currently using UEFI with MemTest86 6.3 running the stock test.
    There's a couple of pictures included. I'm unable to save any files currently as this is the only computer I have, and it's BSODing all over the place.
    Any helps appreciated
    A combination of blue screen screen errors and MemTest86 reporting RAM errors is pretty conclusive. You have a hardware fault.
    There are no bugs like this in the current release of MemTest86.
    • NoPleaseNotTheRAM
      • Feb 2016
      Thank you David, it's currently reached 1.7 million errors and, having used the software before, I just couldn't believe there were that many errors.
      Keep up the good work man
      • Neil
        • Feb 2016
        when you say a hardware error are you meaning his RAM or general hardware failure. I too am getting frequent BSODs and my eror count is up to 12,500 and still going with a few on test #1 and #2, 200 in #3 then going into the thousands after that. Not sure if I need new memory or a new computer
          Errors can be caused by the RAM, motherboard, the RAM slot or the CPU.
          Or even by external factors such as high temperatures, dust and dirt on connectors, corrosion, electromagnetic interference or cosmic radiation.
          But most of the time it is the RAM that is bad, and that should be what you replace first.
