Memtest and USB stick
  • skorpov
    • Apr 2016
    hi.
    i downloaded memtest and put it into an usb stick to run the test.
    now i wanted to format my usb stick but it says it's just 50mb space in total instead of 32gb.
    any ideas how i can solve?
    If you used Windows to create your MemTest86 USB flash drive, then open up imageUSB again and select the Zero option (optionally Zero MBR only) and this should clear any disk layout information of the USB flash drive and Windows will prompt you to reformat the device. Or the Reformat option should work also.
    If you used Linux, you can use fdisk (or simliar disk partitioning util).
