Microsoft Surface Pro
  • Jwynn
    • Jun 2016
    I'm running into some real issues, BSOD, memory errors. I've run the tool as well as some additional Microsoft dumps - any idea what's going on?
    One Drive results:
    https://onedrive.live.com/redir?resi...t=folder%2clog
  • Jwynn
    • Jun 2016
    Update - Surface Pro - Windows 10
    Note: I'm using Windows 10.
    One Drive results:
      It looks like you may have faulty RAM. Try replacing your RAM with known good modules and see if you are still getting errors.
      See this page for details:
      http://memtest86.com/troubleshooting.htm
      • Jwynn
        • Jun 2016
        Hi Keith, unfortunately, a surface pro is a closed system - no way to replace the RAM. Is there anything you can think of that points to faulty memory and not OS issues.
          The MemTest86 log indicates memory errors in multiple tests, so there is a good chance that the memory is faulty. MemTest86 runs without an O/S installed so it is unlikely an O/S issue.
          • Jwynn
            • Jun 2016
            Update
            Hi Keith,
            Were you able to access the report and the errors you are seeing point to fault memory?
            thanks
              The MemTest86.log file included log entries of detected memory errors such as this:
              [MEM ERROR - Data] Test: 8, CPU: 0, Address: C57D9840, Expected: 6133CA55, Actual: 6033CA55
              Although it is more likely to be RAM issues, there is also the possibility it could be other components in the memory datapath (CPU, cache, etc).
