Core Ultra5 225h CPU machine test memtest86 randomly freeze
  • C.C
    • Nov 2019
    • 10
    I have tested a set(2PCS) of 6400 32GB CSODIMM on different 4 platform
    There are
    1.NUC(CPU: Ultra5 225H)
    2.MINI PC(CPU: Ultra5 225H)
    3.CSODIMM Platform (CPU: Ultra5 235)
    4.ECC CSODIMM Platform (CPU: Ultra5 235)
    Using the Memtest pro version 11.5
    When the set test on 1&2 machine , it freezes in randomly time (caused on 1 hour , 12 hour , 20 hour , not the same every time )
    But the same set test on 3&4 machine, it can PASS 24 hour even more
    Is it a known issue on arrow lake H cpu series? Or the set of CSODIMM are actually corrupted?
    • 11127
    There are no known freezing issues on any current CPU (with the current software).
    A freeze doesn't have to be bad RAM. Could be the CPU or motherboard. Could also be temperature related or BIOS settings.
    • C.C
      • Nov 2019
      • 10
      Hello David,
      I found that while the sets freeze on Ultra 5 225H machines, it always freeze on test 9
      Did you have any suggestion that I can adjust on BIOS or test configuration of memtest?
        • 11127
        You could try running the RAM at a slower speed.
        • C.C
          • Nov 2019
          • 10
          Hello David,
          I update all test to Memtest Pro version V11.6
          I have tested 2 set(4PCS) 32GB CSODIMM which hang on 6400MHz ,
          when I down grade at 5600MHz on the NUC(Ultra 5 225H) , it can pass on more 24hours .(While 6400 MHz still freeze on Test 9)
          So I borrow more machine to test
          All I tested machines :
          5.MINI PC(CPU: Ultra7 255H , same series model with No.2 but different CPU)
          6.Laptop PC(CPU: Ultra9 275HX)
          The 2 sets (4PCS) Modules only freeze on Test 9 while using No.1 and No.2 machine (Both CPU : Ultra5 225h)
          The other machines (No3.~No.6) all can test PASS over 24hours
          Did you have any suggestion that I can adjust on BIOS or test configuration of memtest on Ultra5 225h machines?
            • 11127
            You could check for new BIOS on the bad machines.
            Or just accept that those first two machines aren't capable of running the RAM at 6400MT/s fast in a stable fashion.
            (or you could start playing around with all the RAM timings, but we never bother with that. It is a lot of work for a minor gain and really the RAM should just work with the profiles it advertises)
            • Jessica
              • Dec 2025
              • 14
              Hi C.C.
              We have similiar experience. (same CPU ultra 225h )
              frequently freeze at test9
              If we disable all e cores (just use p cores), we can pass all the test.
