PC Crashing: Memtest86 finds a Stick with Lots of Errors
  • shadow24
    • Jul 2024
    My PC has been crashing often recently. I tested every stick and slot using memtest86 and one stick had a lot of errors. Is the ram stick defective? Any help is appreciated.
    Summary
    Report Date 2026-04-12 19:33:01
    Generated by MemTest86 V11.6 Free (64-bit)
    Visit MemTest86.com to Upgrade to Pro
    Result FAIL
    System Information
    EFI Specifications 2.70
    System
    Manufacturer ASUS
    Product Name System Product Name
    Version System Version
    Serial Number System Serial Number
    BIOS
    Version 3636
    Release Date 01/04/2026
    Baseboard
    Manufacturer ASUSTeK COMPUTER INC.
    Product Name ROG STRIX B550-F GAMING (WI-FI)
    Version Rev X.0x
    Serial Number
    CPU Type AMD Ryzen 7 3700X 8-Core
    CPU Clock 3594 MHz [Turbo: 4267.3 MHz]
    # Logical Processors 16 (8 enabled for testing)
    L1 Cache 16 x 64K (231267 MB/s)
    L2 Cache 16 x 512K (69280 MB/s)
    L3 Cache 1 x 32768K (23679 MB/s)
    Memory 16313M (9132 MB/s)
    RAM Configuration DDR4 2134MT/s / x1 Channel / 15-15-15-36 / 1.200V
    Number of RAM SPDs detected 1
    SPD #0 16GB DDR4 XMP 2Rx8 PC4-28800
    Vendor Part Info G Skill Intl / F4-3600C16-16GVKC
    JEDEC Profile 2134MT/s 15-15-15-36 1.2V
    XMP Profile 1 3602MT/s 16-19-19-39 1.35V
    Number of RAM slots 4
    Number of RAM modules 1
    DIMM B1 Empty slot
    DIMM B2 Empty slot
    DIMM A1 16GB DDR4 2R PC4-17000
    Vendor Part Info G Skill Intl / F4-3600C16-16GVKC / 00000000
    SMBIOS Profile 2133MT/s 1.2V
    DIMM A2 Empty slot
    Result summary
    Test Start Time 2026-04-12 15:35:44
    Elapsed Time 3:56:14
    Memory Range Tested 0x0 - 430000000 (17152MB)
    CPU Temperature Min/Max/Ave 43C/64C/52C
    Lowest memory speed 2134 MT/s (15-15-15-36)
    Highest memory speed 2134 MT/s (15-15-15-36)
    # Tests Completed 48/48 (100%)
    # Tests Passed 7/48 (14%)
    Lowest Error Address 0x3FDF2034C (16351MB)
    Highest Error Address 0x3FFF241C0 (16383MB)
    Bits in Error Mask 00000080000000A0
    Bits in Error 3
    Max Contiguous Errors 2
    CPUs that detected memory errors { 0 }
    Bits in Error
    . . . . . . . . . . . . . . . . . . . . . . . . x . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . x . x . . . ..
    63 0
    Test # Tests Passed Errors
    Test 1 [Address test, own address, 1 CPU] 0/4 (0%) 4
    Test 2 [Address test, own address] 0/4 (0%) 5
    Test 3 [Moving inversions, ones & zeroes] 0/4 (0%) 149
    Test 4 [Moving inversions, 8-bit pattern] 0/4 (0%) 597
    Test 5 [Moving inversions, random pattern] 0/4 (0%) 680
    Test 6 [Block move, 64-byte blocks] 0/4 (0%) 532
    Test 7 [Moving inversions, 32-bit pattern] 0/4 (0%) 1863
    Test 8 [Random number sequence] 0/4 (0%) 141
    Test 9 [Modulo 20, random pattern] 3/4 (75%) 1
    Test 10 [Bit fade test, 2 patterns, 1 CPU] 0/4 (0%) 10
    Test 13 [Hammer test] 0/4 (0%) 38
    Last 10 Errors
    2026-04-12 19:30:21 - [Data Error] Test: 13, CPU: 0, Address: 3FDF237C4, Expected: 8222BC3D, Actual: 8222BCBD
    2026-04-12 19:29:51 - [Data Error] Test: 13, CPU: 0, Address: 3FDF23A5C, Expected: 496AC88A, Actual: 496AC80A
    2026-04-12 19:28:50 - [Data Error] Test: 13, CPU: 0, Address: 3FDF237C4, Expected: 762DB406, Actual: 762DB486
    2026-04-12 19:28:20 - [Data Error] Test: 13, CPU: 0, Address: 3FDF21E54, Expected: 9B3BFEC5, Actual: 9B3BFE45
    2026-04-12 19:28:20 - [Data Error] Test: 13, CPU: 0, Address: 3FDF21B84, Expected: 2AB58EC1, Actual: 2AB58E41
    2026-04-12 19:26:36 - [Data Error] Test: 13, CPU: 0, Address: 3FDF237C4, Expected: 326BED25, Actual: 326BEDA5
    2026-04-12 19:25:54 - [Data Error] Test: 10, CPU: 0, Address: 3FDF21B84, Expected: FFFFFFFF, Actual: FFFFFF7F
    2026-04-12 19:20:48 - [Data Error] Test: 10, CPU: 0, Address: 3FDF237C4, Expected: 00000000, Actual: 00000080
    2026-04-12 19:00:19 - [Data Error] Test: 8, CPU: 0, Address: 3FDF237C4, Expected: 5B3C1241, Actual: 5B3C12C1
    2026-04-12 19:00:19 - [Data Error] Test: 8, CPU: 0, Address: 3FDF2034C, Expected: 119787F7, Actual: 119787D7
    • 11127
    Errors are bad.
    Replace the bad stick. Generally speaking they can't be repaired.
