v11.6 Pro Hang on Arrow Lake (Test 9): Stable with 14 Cores, Fails with 16
  • Jack51041
    • Dec 2022
    • 12
    Dear Sir,
    Technical Issue Report: Core-Specific Program Hang on Arrow Lake (v11.6 Pro)
    Problem Description: We are reporting a reproducible program hang (application stops responding) when running MemTest86 v11.6 Pro on Intel Arrow Lake platforms (Core Ultra 265H and 285H).
    Symptom: The program hangs specifically during Test 9 [Random number sequence].System Status: This is a software-level deadlock/hang rather than a hardware lock-up, as the system remains responsive to Ctrl+Alt+Del to trigger a reset.
    Detailed Test Results & Comparison: We have identified a specific "Core Count Threshold" where the software fails. The system is physically stable (confirmed by v10.6), but v11.6 fails once more than 14 cores are utilized.
    Software Version CPU Configuration (mt86.cfg) Core Count Result
    MemTest86 v11.6 Pro CPULIST=0,1,2,3...13 + ENABLEHT=0 14 Cores PASSED (Stable)
    MemTest86 v11.6 Pro CPULIST=0,1,2,3...15 (or Default) 16 Cores FAILED (Program Hang)
    MemTest86 v10.6 Pro Default Settings Full Cores PASSED (24-Hour Stable)
    PS:
    To achieve stability in v11.6 Pro on this platform, the following mt86.cfg parameters must be applied:
    CPUSEL=PARALLEL
    CPULIST=0,1,2,3,4,5,6,7,8,9,10,11,12,13
    ENABLEHT=0
    Best Reagrds
    Jack
    • 11071
    Can you try V11.7 before we look into it too deeply
    https://www.memtest86.com/whats-new.html
    To download the new Pro version, if your support is current, you can login here to get it.
    https://www.passmark.com/login.php
    Unstable software can be caused by unstable hardware. Does this happen on more than one machine, with more than one different set of RAM?
    • Jack51041
      • Dec 2022
      • 12
      Hi David,
      1. 16 Cores (Default): 8 machines experience random hangs during Test 9 within a 4-hour window .
      2. 14 Cores (Manual): 8 machines are 100% stable for 24 hours when restricted via mt86.cfg (CPULIST=0-13, ENABLEHT=0).
      3. v10.6 Stability: All systems previously passed 24-hour runs on v10.6 Pro with full cores.
      4.Thank you for recommending v11.7. Since we are currently using v11.6 Pro, we will check out with our QA.​
      Best regards
      Jack
        Thanks for the details. If possible, can you upload or e-mail a copy of the MemTest86 log under EFI\BOOT\ of the USB flash drive, as described here:
        • Jack51041
          • Dec 2022
          • 12
          Hi Keith,David,
          Following up on the reported program hang during Test 9 on the Arrow Lake platform, Factory's engineer has collected the log file from a system that experienced the failure under the 16-core configuration.
          PS: it's program hang on 38 min!
          Best Regards
          Jack
            Thanks for the logs.
            It appears that the hang is related to the efficiency cores timing out due to taking too long to finish testing. We made some fixes to address similar issues with chipsets with hybrid cores in v11.6 but this may be a more extreme case of it. As such, we made a few additional fixes accordingly.
            Can you give this build a try:
            https://www.passmark.com/temp/memtes...-11.7.1002.zip
            Please send a copy of the logs if possible.
            • Jack51041
              • Dec 2022
              • 12
              Hi Keith,
              Thank you for providing the MemTest86 v11.7 Free Edition for log collection. Please note that the logs we are providing right now are all PASS logs with no failures captured.
              The issue we encountered is that the MemTest86 program itself hangs during testing. This program hang occurs randomly and requires a continuous stability loop test of at least 12 hours to reproduce. Since the Free Edition is strictly limited to a maximum of 4 runs, the test finishes too quickly; therefore, it's difficult to reproduce the failure.
              Therefore, the attached logs only show normal completions and do not capture the actual program hang behavior you need to see.
              Best regards
              Jack
                Thanks for the logs. From those runs, it does appear the problem related to the hybrid cores has been fixed.
                If you can e-mail or DM details of your active Pro license, we can send a Pro version of this build
                • Jack51041
                  • Dec 2022
                  • 12
                  Hi Keith,
                  I didn't see your email address.
                  BR
                  Jack
                    • 11071
                    https://www.memtest86.com/support.html
                    • Jack51041
                      • Dec 2022
                      • 12
                      Hi David,
                      I have already sent it out by mail.
                      thanks
                      Jack
                        • 11071
                        We've sent you a new build by EMail.
