MemTest86 11.7
Hello PassMark Support,
I am investigating an intermittent memory error on an AMD Threadripper workstation and would appreciate your technical opinion.
Hardware configuration:
Four memory errors recorded:
Every error has exactly the same characteristics:
Example from the latest test:
Test: 9
CPU: 0
Address: 0x431657FA4
Expected: E141B64B
Actual: E141364B
XOR: 00008000
Troubleshooting already performed:
We have tested multiple 64 GB configurations, pairs of DIMMs, and individual modules. Many configurations passed four iterations of tests 7 and 9 without errors.
The original 64 GB configuration that previously produced an error later passed the same tests without errors.
The latest 128 GB test ran four complete passes in Single CPU 0 mode and produced one error during pass 2.
MemTest86 also repeatedly logs a warning about a possible BIOS multiprocessing bug, generally involving CPU #15. However, memory errors have also occurred in Single CPU 0 mode.
Questions:
Our next planned test is to repeat the full 128 GB configuration at DDR4-1866.
I can provide the complete MemTest86 logs if required.
Thank you for your assistance.
- CPU: AMD Ryzen Threadripper 1920X
- Motherboard: ASRock X399 Professional Gaming
- BIOS: P3.70 (August 27, 2019)
- Memory: 8 × 16 GB Kingston HyperX KHX2400C15/16G DDR4 (128 GB total)
- Tested memory speed: DDR4-2133 (2134 MT/s reported)
- Timings: 15-15-15-35
- Voltage: 1.20 V
- MemTest86: v11.7 Free, build 1000
| Nov 8, 2026 | 128 GB | 7 | 0x40E6F7FA4 |
| Nov 8, 2026 | 128 GB | 9 | 0x463747FA4 |
| Nov 12, 2026 | 64 GB | 7 | 0x28B2B7FA4 |
| Nov 16, 2026 | 128 GB | 9 | 0x431657FA4 |
- XOR between expected and actual data: 0x00008000
- Only bit 15 is affected (1 → 0).
- Every failing physical address ends in 0x7FA4.
- Errors have occurred in both Single CPU 0 and Parallel modes.
Test: 9
CPU: 0
Expected: E141B64B
Actual: E141364B
XOR: 00008000
Questions:
- Does the repeated XOR mask 0x8000 at different physical addresses suggest a specific data line, memory channel, or memory-controller issue?
- Is the identical address suffix 0x7FA4 significant, or could it result from the access patterns used by tests 7 and 9?
- Is there a known MemTest86 issue with the AMD X399/Threadripper platform that could explain this pattern?
- Can we identify the affected DIMM or memory channel from these physical addresses?
- Would you recommend further testing of the CPU memory controller, motherboard, or DIMMs?
