Hash Sets for USB Installation?
  • SwelterTheChef
    • Mar 2011
    Where do you need to extract the hash sets to when a USB installation has been done?
  • Michael (Passmark)
    • Apr 2007
    • 214
    When you create a USB install there will be a folder in the USB install directory called AppData, which for the USB install acts as a substitute for the normal windows AppData folder. In this folder is another folder called hashSets which is where you should place the hash sets.
      • 11135
      It is also worth noting that many USB flash drives have very poor read write performance when small blocks are read / written at random. (4KB random write speeds of 0.1MB/sec are not uncommon).
      The hash set creation and lookup functions tend to do a lot of random disk access. So this can be slow on slow USB flash drives.
