Won't run on XP SP3 - SHGetStockIconInfo could not be located
  • mjk
    • Dec 2011
    OSForensics runs on Windows 7. But when I try to run it on XP SP3, I get the following message:
    osf32.exe - Entry Point Not Found
    The procedure entry point SHGetStockIconInfo could not be located in the dynamic link library SHELL32.dll.
    After dismissing the message box, the application goes away. What's going on?
    Thanks.
    We are aware of this issue and will be releasing an updated build later today. It was accidentally introduced in our latest patch release. Turns out the SHGetStockIconInfo function isn't available in XP. Sorry for the inconvenience.
    Keith
    • mjk
      • Dec 2011
      Thanks, Keith.
        • 11135
        This has been corrected in release V1.0 build 1005.
        http://www.osforensics.com/whatsnew.html
