call osfmount with python script
  • ttaylor
    • Jan 2013
    I'm attempting to right a python script to mount e01 files using osfmount. The command line I'm using works in the terminal, but not in my script. Is there something special I need to do?
    I'm using python 3.3 and subprocess.check_output command. The gui pops up instead of mounting the image.
    Pertinent lines of code I'm using:
    Code:
    image_file=r'G:\TestImages\myimage.E01'
    cmd_line='osfmount -a -t file -f  ' + image_file + ' -m #:'
    ret_string = subprocess.check_output(cmd_line)
    I'm fairly new at python, but I think this should work.
    • 11135
    While I have done programming in maybe a dozen different languages, Python isn't one of them.
    If, as you say, you have it working from the command line, then there is probably some silly syntax error in your Python script (that isn't obvious to me).
    • ttaylor
      • Jan 2013
      If, as you say, you have it working from the command line, then there is probably some silly syntax error in your Python script.
      Thanks. I figured it was me, but I thought I would ask.
      • ttaylor
        • Jan 2013
        Here is my test code that works...
        Code:
        import subprocess, re
        from time import sleep
        cmd_line=r'osfmount -a -t file -f ' +  image_file + ' -m #:'
        try:
          ret_string = subprocess.check_output(cmd_line, stderr=subprocess.STDOUT, shell=True)
          #Get the drive letter
          if len(ret_string) > 0:
            ret_string=str(ret_string)
            m = re.search(r'[a-zA-Z]:\s', ret_string)
            drive_letter=m.group(0)
            print('Image was mounted on {0}'.format(drive_letter))
            #unmount the image
            sleep(10)
            cmd_line=r'osfmount -d -m ' + drive_letter
            retcode=subprocess.check_output(cmd_line, stderr=subprocess.STDOUT, shell=True)
            print ('Image on {0} was unmounted'.format(drive_letter))
          else:
            print('Image was not mounted')
        except OSError as e:
          print('Execution failed: {0}'.format(e))
        except subprocess.CalledProcessError as e:
          print (e.output)
