Problem with -o format option osfmount
  • jslegers
    • Jun 2011
    • 32
    I have a question. I'm testing the new version of OSFMount and I see that there is a nice option to format newly created ram-disk.
    I use this with my Total Commander to create ram-disks.
    This is how I did it with the "old" 1.5 version
    OSFMount.com -a -t vm -s %2M -m %1
    Format %1 /fs:ntfs /v:RAM-Drive /q /y
    This workt great.
    In version 2.0.1 I'm trying this command
    OSFMount.com -a -t vm -s %2M -m %1 -o format:"RAM-Drive"
    It gives this message :
    C:\Program Files\TotalCmd\Tools\OSFMount>OSFMount.com -a -t vm -s 24M -m S: -o format:"RAM-Drive"
    Creating device...
    Created device 0: S: -> VM image
    But no drive is created.
    If I open OSFMount GUI I see the photo.
    What am I doing wrong ?
    Will there be an option to format the drive as NTFS.
    I'm using Windows 10 64 Bit 1709 Build 16299.248
    The minimum size of RAM disk that is supported by OSFMount using the format FAT32 option when mounting must be a minimum of 260MB. This size requirement is specified in the GUI and the release notes, but it seems we neglected to implement the warning in command line. We'll add the warning to command line for next the build.
    It is something we would like to do and is on the to do list that might be included in future versions, but we don't have a timeline of when it would be implemented.
