Error para crear imagen de disco usb de 2gb
  • wiliam
    • May 2018
    ORFAVOR, SOLUCIONAR ESte problema, NO puedo crear bien la imagen forense de un usb de 2 GB (en formato RAW,E01,EX01), ADJUNTO imagen del error Click image for larger version  Name:	Mensaje error crea imagen en RAW.png Views:	2 Size:	37.5 KB ID:	42281
    y SOLICITO darme soporte en linea, acabo de adquirir el OSFORENSICS V 5..2.1007., todas las versiones pasadas tiene el mismo erorr
    • 11115
    We don't speak Spanish. Sorry. That message was more of a warning than an error.
    If you want to image a USB drive, then you should select the entire drive and not just a partition from the drive. See, Click image for larger version  Name:	DiskImage.png Views:	1 Size:	106.2 KB ID:	42285
    VSS = Volume shadow copy.
    It is normal that USB drives don't support VSS. You can check the "Disable Shadow Copy" option to avoid this warning.
    VSS is not required unless the disk is being written to while the image is being take (e.g. for the machine's boot drive).
    If you are trying to do bulk duplication of USB drives use ImageUSB instead.
