In my last post, the image can't show. So I repost a new one about this.
When I run the base command in "system tools ", some Chinese string can't be outputed in correct Encoding.
The result is below:
The correct one should be below:
I think it is encoding problem.
When I run the internal command in "system tools", I can get correct output.
So I think the output stream of internal command is encoded by unicode.
But in my "cmd", the default output stream is in "GBK".
So can I get the correct Chinese output in the "system tools"?
