RTI2 to RTI1 or RTC conversion
  • lewgoins
    • Feb 2014
    • 8
    I'm using version 3.1 build 1001 (64bit) and downloaded about 200 Gb of Win 8 rainbow tables that were only available in RTI2. Is there a tool in OSForensics that would convert them to RT, RTI1, or RTC?
    Also, is there a way to assign more threads and/or CPU's to speed up the process?
    Thanks!
    Lew
  • Meryl (PassMark)
    • Feb 2011
    • 12
    Hi Lew,
    Unfortunately, there is no tool in OSForensics to convert from one rainbow table format to another.
    You can try downloading rti2rto to do the job, available here:
    https://www.freerainbowtables.com/en/download/
    In regards to multithreading, if you are talking about rainbow table generation in OSForensics, this is done automatically. The number of threads will be the number of logical processors in your machine.
    Meryl
