OSForensics system requirements and resource usage
    • 11135
    For anyone wondering about what CPU and hard drives to use in a forensics system, designed to run OSForensics, we ran a few test and came up with some suggestions here,
    http://www.osforensics.com/downloads...urce_usage.pdf
    A summary of the conclusions where,
    • Most forensics tasks are disk bound and single threaded.
    • Even when not single threaded a two core CPU is enough
    • When picking a CPU, customers should favour a small number of fast CPU cores (e.g. 4 cores at 3.9Ghz) rather than a large number of slow cores (32 cores at 2.4Ghz).
    • Hardware spend should instead be on better disks and SSDs.
    • 11135
    How much RAM do you need to run OSForensics.
    For very light usage you can actually get away with as little as 1GB of RAM. But for any serious work you'll need more RAM. In some cases a lot more.
    RAM usage is proportional to the number of devices / file systems added to the case and the number of files, folders & Emails in those file systems.
    The forensics task that places the heaviest demand on the RAM is creating an searchable index. The more files and Emails you index the more RAM required.
    Here is a very rough guide.
    Number of Files & Emails to index Total RAM suggested
    1,000 2GB
    5,000 3GB
    10,000 4GB
    50,000 8GB
    100,000 16GB
    1,000,000 32GB
    5,000,000+ 64GB+
    Actual requirement will also vary depending on what other software is running on the machine (e.g. VMs can use a lot of RAM) and what type of documents are being indexed (and how much text there is in them).
    Once you start to think about indexing millions of documents is makes sense to split the index. For example have one index for Email and another one for documents. Or have an index per large folder. Or even an index per PST file is you are dealing with millions of Emails.
    If you are running multiple cases simultaneously on the same machine, then more RAM will be required.
    Also if you are running multiple VMs on the same machine, then more RAM will be required.
    More RAM also can lead to more disk caching & faster document processing as a pure RAM disk can be used for document caching in OSF.
    Updated comment in 2023:
    Given the decreasing price of RAM, there is really no reason not to have 32GB+ if you are building a new lab machine.
    You might not need this much a lot of the time, but the incremental cost is low, and it will occasionally be useful.
    I would expect that by the year 2025 having 64GB of RAM will be common place & relatively cheap.
    Comment on ECC RAM vs normal RAM:
    ECC (Error correcting) RAM is nice to have. But,
    1) It is a lot more expensive
    2) You'll probably need a more expensive motherboard & CPU as well.
    3) It typically runs slightly slower than regular RAM.
    If your budget is unlimited, then get it. If it isn't, get normal RAM and run MemTest86 on the machine to validate the RAM is error free (or at least initially error free) before putting the machine into use.
