Need help badly about sound card sampling
  • kazzy33
    • Aug 2004
    Would you PLEASE tell me the amount of ram needed to store 4 seconds of stereo sound on a sound card with 44KHz sampling rate would it be
    A) 180 Kbytes
    B) 704 Kbytes
    C) 440 Kbytes
    D) 512 Kbytes
    I would really appreciate your help,Thanking you kazz.....................
    I am so confused please please please help...
    • 11135
    It is not possible to answer this question without knowing the sampling resolution. Each sample could be converted into either 8,16 or 24bits. The question is incomplete without this information.
    You might want to mention that to your teacher
    Also, we don't do homework.
    Regards
    • kazz
      • 286
      sorry david
      sorry I for got to tell you it is a 16 bits very very sorry.
        • 11135
        Well if your were using Pulse-code modulation (PCM) encoding it would be,
        44,000 sample per chanel per second
        2 stereo channels
        4 sec
        x
        16 bits per sample
        = 5632000 bits
        Divided by 8 bits per byte
        = 704000 bytes
        1 KB is normally 1024 bytes so this would mean the answer is
        E) 687.5 KB
        If you were not using PCM encoding (for example you were using MP3), then the result would be very different.
        PassMark
