DiskCheckup V3.4 Build: 1002 device info for TOSHIBA DT01ACA200
  • GreatHD
    • Oct 2016
    The buffer size for the above drive is reported by DiskCheckup as 0 KB. The drive is specified as having a 64 MByte cache. Can you explain the discrepancy?
    Generated the DiskCheckupLog.txt file using the -d parameter but I cannot upload because 84KB is too big and I cannot copy-paste here because it uses illegal characters
    • 11135
    EMail it to us.
    • GreatHD
      • Oct 2016
      Email sent
        Thanks for the logs.
        The fields "Buffer Size" and "ECC Size" have been deprecated in the data structure returned by the drive. As a result, it should be reported as "N/A" in DiskCheckup instead of "0". This will be fixed in the next release.
        • GreatHD
          • Oct 2016
          Thanks for the clarification and future update
